Does anyone make a block off plate for a tial 50mm BOV?
Just as the title states. Does anyone make a block off plate for a tial 50mm BOV?
I want to temporarily block that flange, and remove the valve but still be able to drive.
If anyone knows a site or plate that makes this please let me know....did search on the forums and google and can't seem to find anything.
Thanks.
Thanks.
I am using this on a diesel engine where the valve is electronically controlled.... not just controlled through vacuum on a gas engine. I want a block off plate just incase the electronic controller takes a crap, where i can simply just block the bov off and still have power to drive.
I tried searching but couldn't find any specific to the BOV, but TiAL does sell block-off plates for their wastegates. If you can't find one and are in desperate need, try emailing TiAL about it. Its probably a simple matter of machining one if they dont make it already
Don't think they sell one.
At less i never found one.
Not to hard to weld one up tho.
Bt why can you leave it in place a d unplug it?
It will if you use a thick O-ring and flattened out the lip on the donor. If one was capable of welding aluminum, I would hope they would have figured that one out...
Haha, maybe... but who in the hell blocks off a BOV anyways? Spend the money to do it right or wait until you do have the money.
We all are more aware of that. What happens when you go above what the spring can hold back? Haha... wow, thanks for the laugh.
