I need help with an engine swap if anyone can help please NOOB
Old Apr 8, 2013 | 10:31 AM
T's Accord's Avatar
Default I need help with an engine swap if anyone can help please NOOB
Ok well i have a 2001 Honda Accord 4cly ULEV peice of crap lol
But I want to get a lot of power under the hood. I have heard a lot about putting a h22 in there but I also want to boost and I heard that the h22 isnt that good for a turbo. So then I also heard that the F23 engine is a lot better for boost than the H series. And i dont know if I should go to a J series or not.. Please help thanks
Old Apr 8, 2013 | 04:38 PM
nus_dogg's Avatar
Default Re: I need help with an engine swap if anyone can help please NOOB
If you want alot of power from the get go, just boost your current F23A4. Otherwise if you want all motor, go H22.
Old Apr 9, 2013 | 09:15 AM
T's Accord's Avatar
What mods would I have to do to the current motor to boost it? Because I want to boost but I want to do it safely with our blowing the motor it's an old motor
Old Apr 10, 2013 | 06:45 AM
T's Accord's Avatar
No one is gonna help me out? Lol :/ sukss
Old Apr 10, 2013 | 07:14 AM
sleepyaccord96's Avatar
h22A and call it a day
Old Apr 10, 2013 | 07:31 AM
ReaperMan's Avatar
if you are going to get an h22 get a h22 lsd tranny or else it ain't worth it.
Old Apr 10, 2013 | 02:40 PM
92 civic ex 4dr's Avatar
You could also so what i did to my old 95 cd5. I just put a 350 small block Chevy with a 700r transmission and a Dana 60 rear end (uncle has about five left) in it. Dumped a qudra jet on top and and hooker headers that dumped right under the seats. Required a lot of chassis modification but looked stock from the outside.
Scared a lot of ricers when they wanted to race me. I always turned the engine off at stop lights and had no neutral safety switch so i could fire it up in gear and slam the throttle. I loved that car. I miss it dearly. ******* cops saying it was illegal and to loud and blah blah......
Posted from Honda-tech.com App for Android
Old Apr 10, 2013 | 03:37 PM
i'd like to see this v8 accord you refer to. why a quadracrap? those are terrible carbs.
Old Apr 10, 2013 | 05:42 PM
I don't have it any more. Got busted racing it. PO PO smashed it. My wife won't let me do it again. I'm going to eventually though. Next time I'm thinking 4x4
Old Apr 10, 2013 | 05:56 PM
nus_dogg's Avatar
Just piece together a turbo kit and get a EMS to get it tuned; since, your's an OBD2.
Old Apr 12, 2013 | 09:03 AM
T's Accord's Avatar
Okay thank you. Im assuming that i would have to rebuild the motor? And get better sleves? All the help is needed thanks.
Old Apr 12, 2013 | 10:39 AM
NZXTInerTia's Avatar
No your sleeves are fine, you can actually boost up to about 9psi safely on all stock components. Suggest rebuilding the rear end, at least mains/rods/pistons/rings if you want to go over that. Valves/Springs would also be wise if you decide on going higher on boost levels. H is better for all motor, F is better for boost (specifically the B2, but people boost B1's fairly often).
Old Apr 12, 2013 | 07:20 PM
nus_dogg's Avatar
Do a leakdown and compression test to see where the condition of your engine's at. That'll give you an idea if you should rebuild it or not. What I would look at is the piston rings which leads you to do that compression test before you start boosting the motor, because that is the weak link when it comes to boosting.
Old Apr 14, 2013 | 06:51 PM
T's Accord's Avatar
And what are the B1's an B2's? What is that?
Old Apr 14, 2013 | 06:53 PM
T's Accord's Avatar
Okay thank you for the help I may use that and go from there sir thank you
Old Apr 18, 2013 | 08:33 AM
T's Accord's Avatar
Anything else that I would need to boost that f23 would be nice to know
JonathanCD5
Aug 31, 2014 05:41 PM
mudpuppy4life
Mar 21, 2013 04:52 PM
fraserboostedh22
May 29, 2009 04:04 PM
92accordundrconst
Apr 3, 2006 11:54 PM
Slomies
Dec 24, 2005 07:05 PM
