My Honda Prelude build!
Over this weekend on my 199 Honda Prelude I, Flushed/replaced the oil, installed a new shift ***, oil filter, cleaned the valve cover ( that thing was CAKED in bad oil. was wayyy in need of a cleaning.) replaced the spark plugs with NGK iridiums, got a new cap & rotor, new vacuum tubing,replaced the knock sensor, fixed the random misfire, cylinder 2 misfire, let me know what you guys think of it so far! I plan on moving the battery to the trunk, deleting the purge evap, cruise control, and A/C. I also plan on wiring tucking. thanks for reading! Constructive criticisim will be much appreciated. :D
Good to see you taking some care and bringing her back to life! As you get to know and enjoy the car more, I am sure more mods will come.
Looks like it could use a good paint cleanup, especially the front bumper, good weekend project to buff it out and polish it well!
Its a 5spd **** that I bought at walmart, replaced it with an OEM one on my Accord so we threw it on there.
The block had so much oil condensation built up in it that it needed to be changed asap, after a couple flushes using poor-in engine flush he'll run the good stuff. The filler cap was COVERED in white goop just from being outside all winter, definitely not a head gasket issue. I personally run Honda genuine, but I will be running royal when I go F/I.
-nzxtinertia
-nzxtinertia
As for plans, I really would like to do a manual conversion, Rims, re-painting the bumper and mirrors, Get the valve cover re-painted, Exhaust, fixing the stock airbox, headers, and a long ways down the road eventually a turbo.
Welp, as you can see, I got a new Denso O2 sensor thrown into it, (No more check engine light! WOO.) The picture with the turbo is just a joke lol. But I do plan on going turbo eventually, also new crank/dampener pulley, Keyway, and a bolt. I'm bringing her back to perfect condition one step at a time. (:
Well here is a little more info for you guys if any of you are still interested, found out that my crank pulley wobble could either be A spacer missing behind the timing cover or it's internal ;/ praying that it's just a spacer, also just put in new headlights.
