Engine harness question
I'm trying to find a part of the engine harness I have the main one that connects to everything on the engine I just need the one on the passenger side that's 3 plugs that goes into the firewall that connects to the fuse box and ecu does anyone know what that part of the harness is called?
It's the harness that plugs into the main wire harness on the passenger side it has 3 plugs then it goes to the fuse box, ecu and I'm not for sure what else. I'm just trying to find out the correct name because when I look for a wire harness all I find is the main wire harness that plugs into everything o n the motor
You need illustration #1?.... i would go to the junkyard and ****** what you need or post a WTB ad in the hondamarketplace as they are over 700 at majestic honda NEW!
coupedragracing
Aug 7, 2011 06:36 PM
AWD: Jeff
Aug 13, 2007 10:14 AM
