B18a Smokes up after sitting for a day
So my B18a in my CRX shoots out bluish billowing smoke after sitting for 12+ hours and stops after about driving a mile. Being almost positive the valve seals were the culprit i replaced them, but even though they are brand new its still smoking also the pcv valve was recently changed as well. any ideas on what it could be? cause i am most certainly stuck....
I was going to say it was possibly the valve stem seals..lol
For the next four mornings, unplug a different spark plug wire each day before you crank it up. If it doesn't smoke one morning, then you know that cylinder is the cylinder causing the smoke. It won't prove anything if it still smokes every day.
Obviously turn it off and put the spark plug wire back in before you drive it.
proliant
25
Nov 1, 2006 10:03 AM
GARBhatch.
23
Jan 13, 2005 05:19 PM
