91 wagon lights/power dim
Old Apr 6, 2013 | 10:19 PM
88ef91r32's Avatar
Default 91 wagon lights/power dim
Well to start i picked this wagon up dirt cheap, i fixed everything except its random power loss'.
When driving everything works fine but at night i notice the headlights go dim and bright a lot, almost looks like i'm flashing high beams at people. all the power inside the car does this as well, heater, cluster lights. I should add that my high beams dont work, they did when i got the car but i haven't looked into it. A few times the stereo has shut off for 3-5 seconds, when it comes back on the battery light will stay solid for however long the radio was off.
also randomly the battery light will flick on and off.
It has a newer battery, i've replaced terminals on it and cleaned corrosion. I added a new battery ground and made sure it was a good connection and also added it to the factory to double up. I added new grounds to the valve cover and checked the connections to the alternator as well. i got the car for way cheaper then a refurbished alternator is going to cost and i'd really rather not spend the money on that unless its the problem. other then this issue the car works perfectly and drives great.
Any help is appreciated! thanks everyone!
edit: I should also add that the car has been doing this since i got it in October. I dont daily drive it, i take it very rarely. thanks again!
stocker2shocker91
Nov 11, 2015 05:02 PM
joevincett
Aug 2, 2008 09:03 PM
MzStreetracer
Mar 6, 2007 08:38 PM
Stars
Nov 25, 2005 12:24 PM
integraboy
Jan 19, 2005 11:56 AM
