Honda CR-V & Element 2WD & 4WD Element & CR-V
My 98 CRV 5spd rt4wd. H2B inside.
Old Apr 6, 2013 | 10:03 PM
leondx's Avatar
Default My 98 CRV 5spd rt4wd. H2B inside.
Hey guys. Thought I'd share my crv. I'm actually in the middle of an h2b swap. Here's how she sits now.
http://i859.photobucket.com/albums/a...pse5507479.jpg
I'll be wiring it up tomorrow and hopefully driving it. Excuse the valve cover as its the temporary one.
Old Apr 6, 2013 | 10:04 PM
leondx's Avatar
Default Re: My 98 CRV 5spd rt4wd. H2B inside.
Old Apr 6, 2013 | 11:00 PM
cjmcleod's Avatar
nice header. dope setup.
i had a crv for a while and I wanted to do a j32 swap so bad. i called hasport about using their j mounts for an ek and they said they didn't think anyones ever even done a j swap on a crv. i didn't care about retaining the shitty *** clutch pack based awd system though.
Old Apr 7, 2013 | 04:44 AM
leondx's Avatar
That was the other swap idea. I may end up doing that down the road when I get bored of this.
Old Apr 7, 2013 | 06:43 AM
Dc2_ShowStopper's Avatar
NICE, IN FOR UPDATES
Old Apr 7, 2013 | 07:01 AM
KrazyRdR83's Avatar
nice...def in for more details
Old Apr 7, 2013 | 01:48 PM
leondx's Avatar
Im a little stuck on the distributor wiring. Im trying to convert my b20b4 distributor plug to the h22a4 2 plug connectors with external coil. Alot of people say match the colors, but they dont match lol
Old Apr 7, 2013 | 01:55 PM
HondaPartsHero's Avatar
Technical Hero
Pm this guy
https://honda-tech.com/forums/showth...3096091&page=1
Old Apr 7, 2013 | 02:48 PM
LDForget's Avatar
i recently had that issue, turned out one set of wires were just a lot more faded than the other. best thing to do is open them both up and just figure out what wires go where, then match those up.
Old Apr 7, 2013 | 05:16 PM
leondx's Avatar
Bluehbcivics motor was designed with internal coil. Doing an internal coil swap now with b20 parts.
Old Apr 7, 2013 | 06:14 PM
LDForget's Avatar
internal coils have a problem where they overheat and you have spark issues. external coils are better.
Old Apr 7, 2013 | 11:48 PM
NZ-DB8R's Avatar
External coils bring more problems than gains. Show me a successful reliable Honda Circuit Car (most extreme conditions, heat/vibration etc) with a external coil.
Old Apr 11, 2013 | 03:51 PM
leondx's Avatar
Got it running right and been driving it. Being nice to it to allow the clutch to properly break in. Damn these 75a mounts are stiff.
Old Apr 11, 2013 | 03:52 PM
leondx's Avatar
Old Apr 11, 2013 | 08:40 PM
Infinity_Racer's Avatar
Can you still retain a/c and p/s with that set up?
Old Apr 12, 2013 | 01:20 PM
eg92b16's Avatar
wow love it same setup i want to do . what motor mounts did u use ??
Old Apr 13, 2013 | 11:19 AM
leondx's Avatar
I wasnt able to retain ac or ps with it. Didnt really try though. As far as mounts, I used the qsd ek h2b kit with innovative motor mounts. Dropped right in aftwr modifying the h2b plate.
Old Apr 13, 2013 | 01:39 PM
eg92b16's Avatar
cool can u take a pic of the h2b kit so i can see what i need to get done
Old Apr 13, 2013 | 04:13 PM
ChaseIntegra's Avatar
Tight! That Bisi header is gangster!
Old Apr 14, 2013 | 08:53 AM
leondx's Avatar
Upload a pic of your plate and ill mark what needs cut.
Old Apr 14, 2013 | 08:54 AM
leondx's Avatar
Gave the crv a few solid runs. Its completely different, I love it. So much faster.
Old Apr 15, 2013 | 09:53 AM
shermanyang's Avatar
Loving it!! Although I'd never do that swap because i need all my essentials - AC/PS/AWD
Old Apr 16, 2013 | 11:22 AM
leondx's Avatar
Well I still have awd...
Old Apr 16, 2013 | 04:46 PM
leondx's Avatar
Took a few more pics.
Old Apr 16, 2013 | 04:47 PM
leondx's Avatar
