P0108 CODE after removing APEXI VAFC
I'm trying to sell my car and after removing my APEXI VAFC my check engine light came on and it says P0108 apparently its the MAP Sensor, but can I do to fix it? I tried to clear the code but it comes right back on. I took the resonator out as well but does that have any effect on it? Please help I would like to sell this asap to get a new car.
Sigh... well i tried to hook it back up to see if it would work again apparently I did more damage then good... My car wont start anymore it will crank but not start. Anyone know what could of happened? Could I have blown a fuse or some sort? This really sucks..
Maybe you unseated a wire from the ECU wiring harness? I don't know where the VAFC even hooks up. If it's tapped into the ECU wiring plugs, I'd start there. Check all the wires/pins. If the car isn't starting, I'm sure you probably have more than just a MAP sensor CEL now too.
South Bay Surfer
Dec 24, 2004 02:15 PM
TurboBumblBee
Nov 8, 2003 10:44 AM
