Ignition Timing problem
Old Apr 6, 2013 | 04:02 AM
BmoreEG's Avatar
Icon2 Ignition Timing problem
Okay so I have a 92 eg hatch si with a B16a2 OBD1 swap I just got the car about a month or 2 ago and the guy was running it with a B18 LS distributor (wtf) so I got a new one and when I went to set the timing, my timing gun was showing that it had to be at full advance for the marks to line up at 16 degrees +2 or whatever it is. I'm fairly new to the honda game but I hear this is really bad for your motor and can melt your pistons. Help me!
Thanks- Nick
Old Apr 6, 2013 | 04:41 AM
Former User's Avatar
Default Re: Ignition Timing problem
If you are able to set the timing to spec, then you're good to go.
Old Apr 6, 2013 | 04:53 AM
BmoreEG's Avatar
Alright so it doesn't matter that it's fully advance then?
Old Apr 6, 2013 | 05:42 AM
HondaPartsHero's Avatar
Technical Hero
Did you jump the service connector as well? What was the procedure you used to set it?
Old Apr 6, 2013 | 06:48 AM
BmoreEG's Avatar
No, I put the crank barring and harmonic balancer at tdc, turned on my car and let it idle for about 5 minutes.. Hooked the timing gun to the number 1 spark plug on the distributor and just rotated it until the red line lined up with the point on my timing belt cover
Old Apr 6, 2013 | 07:52 AM
The engine must be fully warmed up and the service connector must be shorted/jumped when you adjust the ignition timing. See FAQs sticky for diagram.
BmoreEG
Apr 6, 2013 02:41 PM
Slacker93eg
14
Jul 2, 2011 04:27 PM
mrmilitaryguy
Mar 5, 2008 12:24 PM
MrCivic
Mar 4, 2008 07:21 PM
3rdGteg
Dec 1, 2002 08:15 AM
