FS:B18C1 Block , Honda & Acura Shop Sale! 56k No way!
Old Apr 6, 2013 | 12:50 AM
SlaminSohCivic's Avatar
Icon3 FS:B18C1 Block , Honda & Acura Shop Sale! 56k No way!
Hey whats up Honda-Tech Ive got some Parts I Need Gone
PAYPAL Accepted
Location Smithfield ,PA,15478
Phone # 724-984-2168
-B18C1 OBD1 ShortBlock...Bearings Went Bad And Bent a Rod
Includes Everything Cut Crank Pulley &Knock Sensor
Crank Needs Cut Mayb Even a New Crank &Rods Arnt Useable
Good Parts..Block (Not Cracked...Sleeves Are Perfect ....Mains &Girdle...Oil Pan Non Dented...Oil Pick up...22t Water Pump ...Oil Windage Tray...Oil Cooler Set Up...Pcv Box...Pistons...Rear Main Seal...
ASKING $350.00 Picked up Willing to Ship But will be $375.00 +Shipping and Handling
-91 CRX SI 5 Speed Gauge Cluster 103,xxx mILES.....$65.00 Shipped
-D16Y8 Vtec Solenoid....$40.00 Shipped
-B18C1 OEM 3 Bolt Style Aluminum Mount & Mount Bracket $65.00 Shipped
-B18C1 OEM Knock Sensor...Includes 1 Wire Round Plug with 3" Wire $55.00 Shipped
-94 Integra LS OBD1 Non Vtec Engine Harness....$75.00 Shipped
-D16Y7 Hydro Tranny Gear Set....Counter Shaft ,Main Shaft ,Final Drive &Diff &3 Shift Forks....Scyros Are Good....Case Got Cracked From Rock on Road....But as soon as i hit it and seen it was spitin Tranny Fluid i Shut it off
$75.00 Shipped
-B18A1 YS1 Cable Transmission Cable...Great Shape....This case u can put Hydro Gears in it if u need to $115.00 + Shipping
-D16Y8 Stage 1 Vtec Cam....Jernoul Got Scared Not Sure if it Can Be redone or What....Im sure its a Blox or Comp Cam Says P R1 $55.00 Shipped
-b18b1 ls hYDRO Ring Gear....Final Drive $40.00 Shipped
-D15B2 OBD0 Duel Point Distributor $35.00 Shipped
-B18B1 LS OBD1 Distributor $65.00 Shipped
-95 Civic Dx OBD1 Engine Harness....$75.00 Shipped Uncut
-D16Y7 Hydro Complete Gear Set...Counter Shaft ....Main Shaft ...Final Drive &Diff $80.00 + Shipping
-P06 OBD1 Chipped Ecu....Free Basemap Of Choice $105.00 Shipped
-DSM Black Top 450cc Injectors....76k Miles.....New Injector Orings....$75.00Shipped
-92 Civic DX OEM Rear Lower Control Arms...With Energy Suspenion Polyurthane Inserts....All 6 Replaced $65.00 Shipped
-JDM Sport D-Series Logstyle Turbo Manifold....$45.00 Shipped
-Supra Turbo Yellow Top 330cc Injectors...6 of them.....$65.00 Shipped for all 6
-B16A OBD0 JDM Intake Manifold &Throttle Body&IVAC Sensor....$75.00 Shipped
ECUS
OBD0 Manuel PR4 Ecu $50.00 Shipped
OBD0 Manuel PM6 Ecu $45.00 Shipped
OBD0 Manuel PG7 Ecu $65.00 Shipped
OBD1 Manuel P07 Ecu $25.00 Shippedd Injector Resistors are burnt
OBD1 Auto P06 Ecu $60.00 Shipped
OBD2 Auto P2E Ecu $40.00 Shipped
OBD2 Manuel P2P Ecu $50.00 Shipped
OBD1 P06 Chipped Ecu....With Basemap of Choice $105.00 Shipped
-88-91 Civic Integra Black Main Relays $22.50 Shipped Each
-92-00 Civic/Integra Grey/Orange Main Relays $27.00 Shipped Each
-B18C1 OEM Knock Sensor....Includes The 1 Wire Round Plug For knock SENSOR $55.00 Shipped
-b18c1 OEM Oil CoolER OIL FILTER SANDWICH Piece...With the Banjo bolt Included $45.00 Shipped
-92-95 Civic Climate Control Units....With A/C Buttons....Mint condition....$35.00 Shipped Each
-97 Civic OEM Driver Side Head Light....$20.00 + Shippin
-B18A1 Brand New NPR Nippon Racing Pistons...STD Size....With Brand New NPR Piston Rings New....$100.00 Shipped for Pistons &Rings
-D16Y8 OEM Valve Train....Valves , Valve Springs ,Retainers ,Keepers $50.00 Shipped for All
-91 Integra LS 5 Speed Gauge Cluster.....220k Miles....Mint $55.00 Shipped
-95 Civic EX OEM Intake Tube &Air Box $25.00 + Shipping
-D16Z6 Semi-Complete Intake Manifold $55.000 Shipped
-F23A4 ULEV Vtec sOHC hEAD....No Bent Valves...Never Over Heated...Included complete valve train , Distributor ,Plug Wires ,Vtec Solenoid ,Valve Pan Cover $150.00 Shipped
-D15B8 8 Valve Complete Head....Complete OBD1 Intake Manifold Also....$100.00 +Shipping u WILL Get 37+ MPG With this set up
-D16Y7 & Y8 OEM CAM GEAR X2 $15.00 Shipped Each
- D-Series Hydro Front Tranny Torque Mount Bracket Wit Mount X3 $35.00 Shipped Each
-91 Integra B18A1 OEM Pass Side Transmission Mount With bRACKET Under it...$40.00 Shipped
-92 Civic rEAR k fRAME Mount $25.00 Shipped
-D-SERIES Hydro Rear Tranny T Bracket....$35.00 Shipped Each x3 (Not Pictured)
-88-91 JDM B16A CRX SI-R Rear Tranny T -Bracket....Used for B-Series In EF X2 $50.00 sHIPPED Each (Not Pictured)
-3 Bolt Style Aluminum Mount Only $30.00 Shipped
-D16Y8 Motor Mount Bracket...(One For Pillow Mount)
-88-91 Civic/CRX D-Series Cable Rear Tranny Bracket $25.00 Shipped
-88-91 Civic/CRX D-Series Tranny Mount With Bracket $25.00 Shipped
- TONS OF D-SERIES &B-SERIES BLOCK PARTS WHATEVER U NEED LMK AND WE WILL TALK PRICES I DONT HAVE TIME TO LIST ALL THIS
PARTS IM LOOKING FOR
CHARGE PIPING 2.5" FOR 92 Civic
Blow off Valve
B-Series Turbo Manifold
40/40 Prop Valve
EG Hatch Rear Plastics
Old Apr 6, 2013 | 03:51 AM
91zSi's Avatar
Default Re: FS:B18C1 Block , Honda & Acura Shop Sale! 56k No way!
I'm looking for a B series crank pulley. PM me if have one.
Old Apr 7, 2013 | 02:43 PM
It Wasn't Me's Avatar
**EFFECTIVE IMMEDIATELY** From todays date (3/18) onward; anyone selling ANY product in the marketplace will be expected to post a picture of their item for sale with a sign included in the photo. On the sign, should be your username, date and the words Honda-Tech.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Old Apr 9, 2013 | 10:37 AM
bump
Old Apr 11, 2013 | 07:29 PM
I dont understAND Why we got to take a picture of every little thing we sell....Some people work 10 hours a day and sell parts on side...And dont have time.If people is interested in small part they ask then we send picture to them
Bump
Old Apr 13, 2013 | 11:42 PM
BUMP IT UP
Old Apr 14, 2013 | 01:03 PM
mouab18c1's Avatar
Bump
Because there are too many scammers on here. It's not like it takes a load of time to do what they asked.
Old Apr 14, 2013 | 09:05 PM
well Look at my last photo theres over 200 items in that one picture now that takes time to list everything.....when someone can just tell me what they want
Old Apr 14, 2013 | 10:33 PM
mouab18c1's Avatar
I'm guessing only one with the required text is fine.
Old Apr 17, 2013 | 08:37 PM
bump
crazyjetsfan22
Northeast (Sales)
31
Feb 20, 2011 03:00 PM
SpoonSportsJunkie
May 1, 2006 05:42 AM
kingteghelm
May 2, 2005 07:38 AM
Nextelbuddy
Jun 23, 2003 02:23 PM
B20LS-T
Apr 18, 2002 06:14 AM
