Hondata s300 BBG
bought a civic w/ s300 v1 in p28. wondering if there's any way to tell if it had bbg installed.
i checked in smanager on original tune on car and it had some numbers filled in but don't a have a boost solenoid or boost controller installed.
If you dont have a boost solenoid, you do not have BBG
is it possible that boost solenoid was removed?
like i said on original tune...in smanager, boost control section had numbers in them. ie, duty cyle, 1st-5th gear had boost psi enter...9psi-15psi.
Here is the installation procedure:
http://www.hamotorsports.com/pwm-boo...tallation.html
thanks. i'll look inside the ecu to see if those components are there. i'm going retune soon and thought about getting bbg.
on a side note, how is it possible that the ecu isn't fried due to the fact that it has rp/delphi 880cc low impedance injectors and no resistors/box installed?
although, i do have datalogging problems. won't stay running for more than 5-10 secs. i'm thinking that the issue is with the injectors.
