FS/FT K24a2 TSX motor
i have a K24A2 motor out of an acura tsx that would be perfect for someone looking to do a Kswap in their civic or integra. the motor has less than 25k on it and is very clean. looking to trade straight up for a B18C5 or B18C type r long block or will trade for really clean gsr long block plus cash. will consider ls or a well built ls vtec long block or make me a money offer
I was going to go K into my EM1 but decided I just love the B.
I would like to get $1800 for the motor if no one has a good trade on it.
Im not interested in any motors set up for boost at all, I plan on doing NA in my car all the way.
BUMP, Went and re-checked the Vin on the motor. here is some info that i decoded from the vin
Model: TSX
Make: Acura
Manufacturer: Honda Motor Company Ltd.
Model year: 2006
Country (Region): Japan (Asia)
Plant: Saitarna, Sayama
Sequential number: 034964
Model: TSX
Make: Acura
Model year: 2006
i dont really want to go K im cool with staying B, im not trying to build some high horsepower car or anything like that just a car i enjoy driving. I rather put big money into my rat rods and hot rods now
any interest in this:
B18A Block and Crank checked and balanced
JDM SIR P30 pistons
Shot peened ls rods checked and balaned
ARP rod bolts
ACL RACE bearings
OEM seals rings ect.
ITR oil pump
OEM oil pan
Golden Eagle ls/vtec conversion kit
ARP head studs
2 layer head gasket.
OEM GSR water pump and tensioner
South Bend Metal 6 puck sprung clutch.
Fidanza 7.5lb flywheel
GSR head (all work on the head done by Rocket Motorspors)
Mild clean up
Bronze valve guides (un-cut for street use)
Supertech flat faced valves
Rocket motorsports valve train
Rocket M22XX cams
1st Gen Skunk2 Intake manifold
RC310 injectors
STR fuel rail
Hondata Intake manifold gasket
Modified JG Edelbrock RACE header
Toda Timing belt
ST Corsa locking cam gears
Payn Technologies cam seal
JDM SIR P30 pistons
ARP rod bolts
ACL RACE bearings
ITR oil pump
OEM oil pan
ARP head studs
Mild clean up
Rocket M22XX cams
RC310 injectors
STR fuel rail
Toda Timing belt
1zach4
Jul 6, 2004 03:50 PM
