Clueless
so you're going to bypass an issue instead of fixing it?
your heater probably doesn't work because your heater core is probably shot. try replacing your heater core, and your heater might work again.
saying that, yes. you can bypass it. just don't freak out when you cut the hose and the next thing you know you have radiator fluid all over your carpet.
probably only thing broke is the plastic clip which holds the temp control **** cable selector. once it snaps, it no longer opens and closes the valve to the heater core down on the firewall engine side.
