found out car came with rear disc swap...
So i just found out my 96 hatch had a rear disc conversion done. i have no idea what car the parts came out of. So here's the problem, the rear struts are 100% blown thanks to ebay adj coilovers. so i need to replace my struts and pads, but i have no clue what car to get parts for. the car also has aftermarket aluminum lower control arms and rear camber kit for adjustment. Any ideas? I figured if motor wasout of a 95 integra maybe the rest was to. so i cross reference rear strut part #s, and they are different. Someone help!! What do i do?
96-00 rear struts
Look into parts numbers for pads. I am pretty sure you would be able to use teg rear pads. I have a set of pads and rotors which I do not plan on using (I am 4x114 on my teg).
the lower control arms will have to be for 96-00 civic. so as for struts and springs. get 96-00 civic. but you can also use 94-01 Integra or 92-95 civic struts and springs.
for brake pads. take em off and go to the local auto parts store and compare them to 94-01 Integra pads. or civic ex or Si pads
rear disc= same across the board if 4 lug. 94-01 integra pads. make sure you do have ek lca's, post a pic if possible. 92-00 civic/94-01 integra struts will fit regardless, if you have ek lca's, you can shim them with washers. if for some reason you have eg/dc lca's, ek struts will not fit.
L8APX
29
Jul 20, 2008 11:41 PM
DrVtec99
Aug 19, 2006 06:49 PM
