CT 1991 Nissan Sentra SE-R Turbo 400hp ++
Engine: Forged SR20DET Pulsar GTi-R swap
Stock B13 transmission with upgraded clutch.
Jim Wolf ECU
High Flow Injectors
Gas Pressure Regulator
Precision T-62 Turbo
Lag Manifold
Custom Intercooler + Piping
Custom 3" exhaust
AEM Wideband
Greddy turbo timer
HKS blow off
High Pressure Fuel Pump
B&M Short Shifter
Grant Steering Wheel
H&R dropped springs
B14 OEM wheels
New falken tires
Tsuru Front Grill & Headlights
Braille 11.5lbs Relocated Battery to the Trunk
Manual Boost Controler
Boost Gauge on Steering Column
Temperature Gauge
Oil Pressure Gauge
Rotorwork drilled rotors
Solid motor mounts
Ceramic pads
Ngk Bkr6eix-11 spark plugs
New 8mm spark plugs wires
$7,500 Would consider a trade with = Value or reasonable offer
NO RUST BUCKETS !!
Jim Wolf ECU
High Flow Injectors
Lag Manifold
Custom 3" exhaust
AEM Wideband
Greddy turbo timer
HKS blow off
B&M Short Shifter
H&R dropped springs
B14 OEM wheels
New falken tires
Temperature Gauge
Oil Pressure Gauge
Solid motor mounts
Ceramic pads
NO RUST BUCKETS !!
GForceInteg
May 26, 2003 09:46 AM
