es oh es! idle issue :/
Old Apr 2, 2013 | 10:49 PM
ef9kidlulz's Avatar
Default es oh es! idle issue :/
hello interwebz
anyways i got a 1994 civic ex all stock and i'm having an idle issue.
oil change and spark plugs changed. looking to see whats the most common issue before doing something about it..
when its warming up its about at 1300.. once its nice and warm and i reach a stop it drops to 300-400
also its doing horrible on gas
Old Apr 2, 2013 | 10:50 PM
ef9kidlulz's Avatar
Default Re: es oh es! idle issue :/
thinking about changing the spark plug wires or distributor cap but input helps
Old Apr 2, 2013 | 11:15 PM
jbpnoman's Avatar
You need to be more specific. High idle? Low idle? Searching idle? "Idle issue" doesn't tell us anything.
Old Apr 3, 2013 | 01:00 AM
HondaPartsHero's Avatar
Technical Hero
Search the FAQs above for:
How to clean IACV
How to clean FITV
How to adjust idle for 92-95 Civic
How to adjust throttle cable for 92-95 Civic
Old Apr 3, 2013 | 09:17 PM
ef9kidlulz's Avatar
it surges around 300-400 as i stated when stoped. I could look it up but i just wanted to see how many other people have this problem with the same car
Old Apr 4, 2013 | 12:57 AM
apexi_rsx's Avatar
too rich or lean mixture can make idle surge in little increments like your talking.... change the cap, rotor, and wires and see if u still have the problem. sounds like u may need to bump the idle up if need be.... there is a spot above the intake inlet that has a flat head screw in it. usually if it has never been tampered with has silicone all over it and covering it up that may need removed before turning it out. You should be able to adjust ur idle to spec....750-850.... +/- 50 rpms... how many miles are on the motor? Maybe even doing a valve lash may help alittle..
Old Apr 4, 2013 | 06:12 AM
LoganBurris's Avatar
I had the same problem with a '95 as posted above clean the IACV(very very easy) and FITV to start. The former can make an astronomical difference and fixed all problems for me.
hell0curry
Apr 4, 2012 11:20 PM
viciousef9
Jun 18, 2007 03:18 PM
SOHC_MShue
Sep 29, 2003 07:28 PM
