Ground Control Spring rates?
Old Apr 2, 2013 | 03:53 PM
KidZr0's Avatar
Default Ground Control Springs
Hey, guys. I recently purchased some Ground Control springs with spring numbers GC230.64.55 and GC230.64.49. My question is, which ones go to the front and which ones for the back? Also, will they be good for my car according to their spring rates? I own a '95 Civic CX Hatch.
Old Apr 2, 2013 | 04:02 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Ground Control Spring rates?
Plug the numbers into Google. If they are all the same length then it all depends. If you want understeer the higher rates go in front and vice versa if you want over steer.
Old Apr 2, 2013 | 04:09 PM
KidZr0's Avatar
They are all the same length (9 inches). What are good spring rates for front and back for a good nice smooth ride for DD?
Old Apr 2, 2013 | 04:10 PM
The Grumpiest
Smooth is subjective so I cannot answer, Anyone that does is only telling you what is good for them. Otherwise I'm going to tell you to stick with stock. And I don't understand the need to question rates if you've already bought the springs.
Old Apr 2, 2013 | 04:15 PM
KidZr0's Avatar
Well, I pulled a nooby move and bought the springs before really studying about spring rates and all that so I just wanted to know if these will ride well or not :/
Old Apr 2, 2013 | 04:16 PM
The Grumpiest
Put them on and find out.
Old Apr 2, 2013 | 04:19 PM
KidZr0's Avatar
Have to wait til' this weekend since my Koni Yellows won't be coming in til Friday but you're right about that. Hope they will be comfortable..
Old Apr 2, 2013 | 07:49 PM
KidZr0's Avatar
Also, does anybody know if GC coilover springs are compatible with other types of coilover sleeves? Meaning sleeves and adjusting ring are not from ground control but another brand? Or are they only made to specifically fit their own?
Old Apr 3, 2013 | 12:48 PM
KidZr0's Avatar
Anyone know?
Old Apr 3, 2013 | 01:06 PM
azzazel_9's Avatar
why would you put GC springs on some other kind of sleeve?
Old Apr 3, 2013 | 01:49 PM
KidZr0's Avatar
Because I got just the springs for a good deal without the GC sleeves so I thought about putting them on these other sleeves I have on my Civic right now. Know if it'll work?
Old Apr 3, 2013 | 01:57 PM
The Grumpiest
Sure.
Old Apr 3, 2013 | 02:22 PM
azzazel_9's Avatar
try it? Or just buy a full legit set from GC with your own spring rates. Shouldn't have purchased a half set IMO
Old Apr 3, 2013 | 03:07 PM
KidZr0's Avatar
You're right about that. Lol. Just tried to switch everything over to GC strut and stock top hat won't fit cause hole is too small. I believe the coil sleeve should fit though. Now time to look for GC top hats. Know where I can find some other than the site itself?
Old Apr 3, 2013 | 03:32 PM
azzazel_9's Avatar
amazon? Craigslist? Ebay?
Old Apr 3, 2013 | 03:36 PM
KidZr0's Avatar
I was asking more like other good webstores that sell them but thanks for the all the info so far!
Old Apr 3, 2013 | 03:57 PM
azzazel_9's Avatar
none that i know of. Maybe Thmotorsports.com
Old Apr 3, 2013 | 05:52 PM
The Grumpiest
Contact GC and see about getting the parts you are missing.
Old Apr 3, 2013 | 06:31 PM
Laughing Man's Avatar
I've used GC springs on Maxspeed sleves before. Got some Maxspeed c/o's and didnt like the ride on them... few months later found the GC springs in my shead but couldnt find the sleves so i installed them and worked just fine...
dcsports
Suspension & Brakes
11
Dec 31, 2016 08:57 AM
ConfusedEGCoupe
Suspension & Brakes
11
May 31, 2012 06:20 PM
mechanix619
Suspension & Brakes
May 23, 2011 09:48 AM
deviant1
May 1, 2004 03:33 PM
743power
Mar 20, 2002 07:25 PM
