Dash lights not working.
Old Apr 2, 2013 | 03:01 PM
GT500FTW's Avatar
Default Dash lights not working.
When I turn on the headlights, the illumination lights on the dash don't come on.
The battery light and EML still come on as normal. The car runs fine.
I've checked all the fuses in the cockpit, and they're all fine.
Any ideas?
Old Apr 2, 2013 | 03:12 PM
Mr. Bojangles's Avatar
Default Re: Dash lights not working.
Check the dimmer first. Or your bulbs are burnt out.
Old Apr 2, 2013 | 03:14 PM
GT500FTW's Avatar
The bulbs were all working yesterday.
I don't have a dimmer.
Old Apr 2, 2013 | 03:15 PM
grumblemarc's Avatar
The Grumpiest
Underhood fuses.
Old Apr 2, 2013 | 03:19 PM
GT500FTW's Avatar
I'll check them.
Thanks.
Old Apr 2, 2013 | 06:07 PM
NVturbo's Avatar
O.G. triple O.G.
No dimmer rotating switch on the side of the dash? That's odd.
Old Apr 3, 2013 | 01:27 AM
GT500FTW's Avatar
I don't have a dash either.
I removed it.
Old Apr 3, 2013 | 02:26 AM
The Grumpiest
So is the OP a legit question?
Old Apr 3, 2013 | 02:57 AM
jbpnoman's Avatar
Well there's your problem - you went messing with electrical systems you obviously don't understand.
Old Apr 3, 2013 | 01:31 PM
GT500FTW's Avatar
Obviously.
Old Apr 3, 2013 | 01:34 PM
GT500FTW's Avatar
The op is a legit question. Poorly phrased though.
I don't have a dash, but I do have clocks.
The clocks work perfectly, but the illumination lights that usually come on when you turn on the headlights aren't coming on.
It makes night driving a pain...can't see how fast I'm going.
Old Apr 3, 2013 | 01:38 PM
GT500FTW's Avatar
You're stating the OBVIOUS.
If I knew everything about electrics, would I be asking questions on this forum?
OBVIOUSLY not!
Do you have a solution to the clock lights problem I have, or would you just like to point out the OBVIOUS?
Old Apr 3, 2013 | 01:40 PM
Former User's Avatar
What car do you have?
Old Apr 3, 2013 | 01:45 PM
GT500FTW's Avatar
I have a Citroen Ax.
I have fitted a B16a2 engine to it.
Did a full loom conversion from a Del Sol.
Old Apr 3, 2013 | 01:47 PM
Haha...what year Del Sol wire harnesses? Did you also use the Del Sol fuse boxes?
Old Apr 3, 2013 | 01:49 PM
GT500FTW's Avatar
I was refitting a speedo converter to the back of the clocks, and when I finished, the lights don't come on. Haha
Old Apr 3, 2013 | 01:50 PM
You didn't answer the questions. And you probably blew a fuse.
Old Apr 3, 2013 | 01:51 PM
GT500FTW's Avatar
It's a 1993 del sol loom.
It's a Japanese import too.
I kept both of the fuse boxes, yes.
Old Apr 3, 2013 | 01:52 PM
And installed them in the Citroen Ax along with the wire harnesses?
Old Apr 3, 2013 | 01:53 PM
GT500FTW's Avatar
I'm not trying to be rude and ignore your questions.
I double posted and you replied before I could post my second post.
Old Apr 3, 2013 | 01:54 PM
GT500FTW's Avatar
Yes. I did a full loom conversion.
The only electrics in the car are from the del sol.
Old Apr 3, 2013 | 01:56 PM
Voltage test 10A dash fuse 19. Click the Test Fuses link in my signature.
Old Apr 3, 2013 | 02:21 PM
GT500FTW's Avatar
Thanks for the info.
Old Apr 4, 2013 | 12:16 PM
GT500FTW's Avatar
Fuse 19 along with all the other fuses are fine.
Found another few problems.
The cooling fan isn't engaging (I tested it and it does work)
The rear fog light isn't working (and the light on the switch isn't wotking either)
Could this all be related?
Old Apr 4, 2013 | 12:34 PM
Did you voltage test fuse 19.
