First time at track with rex
Old Oct 22, 2002 | 12:54 PM
b16_incarnate's Avatar
Default First time at track with rex
Went to the track for the first time ever and i got a total of 4 runs. My very first run the track surface surprised me and i got a 15.6, my next 3 runs all were messed up launches and i got a 15.1 @92 and a 15.001@93. The machine was broken so they had no 60' times, but know they sucked. I am running some 13 inches tires, does that effect 60 ft. times? I know i can run 14.6's ill go back next week! Every time i launched i would either spin bad or bog bad...weird ****
Old Oct 22, 2002 | 08:22 PM
EFing8's Avatar
Default Re: First time at track with rex (b16_incarnate)
Those are crappy times you are running. You have the lightest model EF and some nice bolt ones. I would think you should run a 14 flat or even a 13.9 with your setup.
Old Oct 22, 2002 | 08:31 PM
USDM 4G VTEC's Avatar
Default Re: First time at track with rex (CND_CRX)
u crazy yo
with that setup he might run anything from 14.6-15.6.... its not a ******* h22.... with all that **** he can run good but not all that.... maybe he can get mid 14's with slicks.... my buddy has a CRX with an LS with a 50 shot and slicks and he touches 14.5....
[Modified by JDM EF9, 12:32 AM 10/23/2002]
Old Oct 22, 2002 | 08:34 PM
91SIvic's Avatar
bog? isn't that bad?
Old Oct 22, 2002 | 09:38 PM
gsl_05's Avatar
Default Re: First time at track with rex (91SIvic)
Hmmm...that's not too good. I ran a 15.8 w/ the D16 motor and bolt ons on 16' Circut 8's. Better work on that launch....
Old Oct 22, 2002 | 09:51 PM
EFing8's Avatar
Default Re: First time at track with rex (gsl_05)
I ran 14.8 in a 90 Si b16. w/ intake and a chipped ecu on on street tires.
HF is 300lbs lighter and he has more mods. i would say it should hit a low 14.
Old Oct 23, 2002 | 04:42 AM
EP3_05's Avatar
Yeah man work on your launch and then you will be able to get down in the 14's. The hf is a lot lighter than all the other models so you should be easily in the 14's. By the way what were you launching at?
Old Oct 23, 2002 | 08:39 AM
Default Re: First time at track with rex (91civic)
I was keeping it steady at 3k just before engagement point, and as soon as it turned green i would drop it. In the streets when i do that i get a nice launch with minimal wheel spin, when i did it at the track i bounced forward really quick and then bogged for a bit before getting traction. Then i did it a little higher like 3.5k and it spinned out too much. I have crappy tires, but **** i should at least get 14s. My 15 flat i revved like at 1.5k and just went out of the blocks as carefully as i could and i managed a 15 flat, man i wanna know so bad what 60' times are. I think i should be in the 14.5 territory.
Old Oct 23, 2002 | 08:54 AM
incubus's Avatar
man I hope I do better than that with my '91 hf/b16 w s1 tranny, how stiff is your suspension? mabey u should get some better tires. Grip and suspension are real important for those '60ft times.
Good luck getting down to 14.5, u can do it!
Old Oct 23, 2002 | 09:12 AM
SpeedMonkeyRacing's Avatar
on slicks maybe...
and if you think b16 crx hf can run 14 flat on street tires...you're wrong.
Jeff-
[Modified by Corporal-Jeff, 1:12 PM 10/23/2002]
Old Oct 23, 2002 | 09:16 AM
therealciviczc's Avatar
Don't drop the clutch with street tires. Ease it out really quickly if that makes sense. Try to keep a nice balance between traction and a little tiny bit of clutch slipping.
Old Oct 23, 2002 | 09:45 AM
Dancing is Forbidden's Avatar
Default Re: First time at track with rex (therealciviczc)
I dunno. Theres a EG here with a B16a swap and DC header that runs 13.9-14.1. Isnt that chassis heavier?
Old Oct 23, 2002 | 09:53 AM
2_Jay_Z's Avatar
Default Re: First time at track with rex (EF9_SiR)
I belive it is.
Old Oct 23, 2002 | 10:04 AM
Urban Business
Guest
Posts: n/a
yeppers blend it. dumping in any situation causes problems. ie you losing
Old Oct 23, 2002 | 10:55 AM
smithbling's Avatar
Default Re: First time at track with rex (TorteX)
At 93MPH you aint gonna do much better than a 14.6-14.7, is the tune right or what?? RICH?
Old Oct 23, 2002 | 01:13 PM
lazy bum shaughn's Avatar
Default Re: First time at track with rex (smithbling)
How is the elevation up there?
Old Oct 23, 2002 | 01:36 PM
Rob!'s Avatar
Default Re: First time at track with rex (El Breako Dancero)
easy on him it was his 1st time
aaronISthrowed
Feb 15, 2007 06:46 PM
b19coupe
Feb 8, 2003 12:44 PM
Evil EG
Jul 3, 2002 09:12 AM
stevel
Jun 6, 2002 10:28 AM
mikeSONICGSR
Nov 5, 2001 07:02 PM
