Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Topping off the Oil
Old Apr 2, 2013 | 07:32 AM
kevinmcc2's Avatar
Default Topping off the Oil
Okay here is my situation. I own a 2009 Civic Si and am a little low on the oil and want to know what oil to top it off with.
I called up the shop that did the oil change and asked them what oil they used to fill the car with..
The answer I got was Honda Conventional Blend. So should I just go to Honda for a quart of oil?
ALSO the car has 57,000 miles on it... Should I switch to synthetic?
The car uses about half a quart every 1200 miles.. (VTEC A LOT)
Old Apr 2, 2013 | 01:13 PM
av911's Avatar
Default Re: Topping off the Oil
You can use any motor oil as long is it's API certified, 5w-30.
Old Apr 2, 2013 | 02:23 PM
TorontoHonda's Avatar
5W30 Grade oil as stated above. if you are just topping off you dont have to be overly concerned with mixing oils.
Josh303
Honda CR-V & Element
Jul 21, 2014 06:23 AM
Wish2345
26
Mar 23, 2010 01:47 AM
KFRG
Feb 8, 2010 05:56 AM
RickSlick
Honda Fit
22
Feb 8, 2010 03:19 AM
Edwin
Jul 19, 2001 06:14 PM
