Air Leaking??Loosing Compression??
Old Apr 2, 2013 | 04:46 AM
242potatoehead's Avatar
Default Air Leaking??Loosing Compression??
hey team, i have a f22b2 all stock. ive went to do a f22b1 sawp but that head was having problems, so i routed back to the 16 valve. i put the head on torque it down, re timed everything to exacts!. Before i went to start it, i manually cranked the engine from the crankshaft pulley and keep hearing air being pushed out. ive gotten all cylinder compression tested and their reading 150. I tried starting it a few times and as it rolled over i heard a backfire.
Any suggestions?? my onli thought was its coming from my intake manifold.
Old Apr 2, 2013 | 05:33 AM
92 civic ex 4dr's Avatar
So you did a b1 head swap and then went back to the b2 head? It sounds like your timing is off if it's pushing air our the intake.
If you have 150psi in all four cylinders that suggests to me that your valves are not bent and your head gasket is fine. Double check your timing. Never hurts. Especially make sure your tensioner pulley is nice and tight
Posted from Honda-tech.com App for Android
Old Apr 2, 2013 | 09:01 AM
Default Re: Air Leaking??Loosing Compression??
Gotcha! i was unsure on the oil pump timing, how it has a lil notch on the shaft, but then also have a marking of the face of the gear. i set it to the little line/slit on the face of the gear not the shaft. You what i mean??
Old Apr 9, 2013 | 08:03 AM
Soooo ive tripled checked everything and still the same results! do you have any other suggestion as to what it may be??!
Old Apr 9, 2013 | 08:13 AM
I'm kinda lost. The engine backfires while running? When you turn it by hand it's normal to hear air being push out/sucked in.
Old Apr 9, 2013 | 07:13 PM
nus_dogg's Avatar
Where was the air being pushed out? Throttle body? Spark plug holes?
Old Apr 11, 2013 | 07:37 AM
it backfire when i try start it,sounds like its coming from the throttle body.
boostedrust
29
Aug 20, 2014 08:28 PM
Matgallis
Apr 2, 2009 02:24 PM
dskater4111
Aug 13, 2008 05:17 AM
RoB316
May 14, 2007 04:08 PM
Peter K
Jul 1, 2002 05:14 PM
