B18c1 head off Low compression. Pics.
So, I had my gsr swap in my 00 ex for about 2 weeks.. one night after driving spiritedly ..I awoke to a Subaru sounding gsr..did compression test..all cyl's were 203-210 except for cylinder one (closest to timing belt) Which tested 155psi. I put a little oil in the cyl. redid the test. 160psi.. So..
I had pretty much ruled out rings..But now that the head is off... None of the valves look bent or burnt..The head gasket looks intact... And you can still see the crosshatching in the cylinder walls..I Also under the advice of a honda guru.. was told to put the head on its "side".. and fill all the intake ports with water.. then clean. dry.. and do the exhaust ports also.. After 5 minutes on each side.. I saw no water leaks from the valves what so ever..Im stumped...But ive provided some pics to see if maybe a more trained eye or eyes on here.. will notice something I did not. I truly hope it is not the rings.. Cuz then im in it deep...Ty ahead of time.
So Ill get right to the only thing I could possibly say looked out of place..cyl 1...this is the low compression cyl does this look like significant enough to caugh a 70psi drop in cyl pressure? :::
there is a tiny.. idk.. "nick" on the edge of piston of cyl #1.: doesn't look like major damage at all.. its very very small and is only on the top of the piston surface::
Here is front and back of headgasket that came off it:
Here is the head, first pic is the whole head and all the valves... second is of cyl 1 up close.::
this is a top shot of the block with the head off:
and the surface on the driver side of the block:
lemme know what you guys think. and thank you!
Re: B18c1 head off Low compression. Pics.
Pour some oil in the bad cylinder and leave it for a little while. Does it drain down into the engine or does the piston & rings keep it in the cylinder?
are any of those marks on the cylinder wall bad enough that you can feel them like with your finger nail?
Leak down was done. I couldn't hear air leakng through exhaust. No bubbling in the coolant...I added oil after I did the compression test and redid it. Compression barely went up. So the machine shop where I took my head for a leak test.. thinks with such little damage to the cyl wall.. that something small may have gotten into the motor (with the tiny ding on the piston and he found a correlating mark by the valve in the head) The marks in the cylinder wall are barely visible and you can't really feel them unless you use your finger nail and even then its barely...machine shop will call me today. And I just put some oil on that piston. Thanks for the suggestions! Will update asap..
Fish Twig
Looks like loose unknown particles getting flung around in the combustion chamber. Damn sucks, when you bought it did you fire it up to hear it?
Check your head for warpage with a straight edge paying specific attention to areas around # 1 cylinder
Wouldn't hurt to check block as well.
okay! thanks for all the suggestions. I brought it to a good machine shop, and right away he saw damage to the seat on one of the valves above cyl 1...something must've got into the motor he speculated. At any rate.. he redid the seat.. resurfaced the head. (dont know how much, but he described it as a "just a little off the top") .. but I couldnt def tell it was resurfaced.. which i'm assuming is standard... and he rechecked the head for leaks.. and we are good 2 go!
Also, i left oil on top of cyl 1 piston..for 24 hours.. and none of it leaked down. So rings seem good also! finally, good news.. Now my question for you guys is.. he said run oem headgasket.. so I ordered one from acura.. will I be able to time the motor with it being resurfaced..?? and stock 3 layer HG? I did alot of searching but no definitive answer..the belt only had 5k miles on it so im reusing it.. stock cam/camgears, I left the belt on the motor and kind've slipped it off the cam gears..I have never had any luck getting the crank pulley off...So Can I do this.. with stock HG...belt still mostly on the motor..and just the hash marks? I read some heads need cam gears after resurfacing...? Idk I cant call him till monday to find out how much he took off..Any suggestions of prepping myself for this job? now that ive spent so much time, blood, sweat on this thing I dont want to mess it up putting it back together.. TY!
Fish Twig
There is a marker at the corners of the head, in the shape of a small circle. Those are used to gauge how much you can take off before you are no longer within spec of the helms manuals spec. He probably knew what he was doing but if you want to check than the helms manual has a guid for that.
if it sound like a subaru are you sure that it not an igniton problem? If a spark plug didn't fire it sound like a subaru
But Like I said.. I just wanted to say thank you guys.. HT has been invaluable to me during this learning process! This was my first, pulling of a d, swapping of the b.. disassemble and soon reassemble of a b series head.. and my first head gasket.. so please bare with me. But I just wanted to take a second and say thank you. And without any further rant or delay by me.. the pic i promise..you can clearly see where it was pressing into the seat... Also is this going to raise my compression slightly? ty again everyone!
Its a square tab on the head. On the very edges of the head. Once that tab is gone the head is done. I needed adjsutable cams after the 4th resurface. Ill take a pic when I get home.
I would def try and get that crank pulley off. You can buy or borrow the tool to hold the actual pulley as you loosen the bolt.
Also you should have checked your valve lash. I'm suprised the vet in here didn't mention it. If the valve lash is just a little too tight it'll keep the valve from closing and you'll end up with low compression.
You can do the belt without taking off the pulley. You will need a coat hanger or whatever you can find to pull up on the tensioner because the cover is in the way.
The timing has to be spot on. If its off half a tooth you will need cams or need to retard or advance either cam when installing the belt. Its a pain in the *** and takes lots of practice.
Take a pic of the bottom of the head and we can point out where the tabs are.
GDD Member
Do you take the spring off to do a belt?
Ya know.... you can loosen the tensioner nut, push the tensioner down, and tighten the nut again, right? When you're all done, you loosen the nut and the belt tightens itself, then tighten the nut again.
But this whole timing thing, uhg.. He also spoke about how motor only counter clockwise while belt is on. and hash marks must meet in center off the two cam gears..Ive searched/read quite a bit and saw some youtube vids. Hoping it will make more sense when its right infront of me
Fish Twig
Yes you can set it with the crank pulley is still on AS LONG AS YOU HAVE THE LOWER TIMING BELT COVER ON. Without that lower timing belt cover you are screwed. All you need to do is line the mark on the crank pulley, the lonely mark that is farthest away from the other 3, with the mark on the timing belt cover.
