GSR build need your thoughts
Old Apr 1, 2013 | 08:53 PM
rza619's Avatar
Default GSR build need your thoughts
-EdelBrock JG intake manifold
-DC 4-2-1 Carb Header
-OEM CAT
-AEM CAI GSR
-2.5 Inch Piping with RSR muffler
-Crower stage 2, camshafts
-Crower titanium springs and retainers
-stage 2 port and polish
-AEM cam gears
-5 angle valve job (stock valves).....head was sent to the machine shop prior to being built, resurfaced, valve job, ect.
-RC 310cc injectors
-Type R water and oil pump
-ARP head studs and ARP connecting rod bolts
Short Block
-block resurfaced and bored over .75
-ACL race bearings (rods, main, and crankshaft)
-jdm b16 high compression pistons pr3 (bored over .75)
-stock gsr crank and gsr rods
https://www.box.com/s/hxh8ds7ev1aw9ix0wjl3 here is the graph
and a video
https://www.box.com/s/8rby3np7pn6cwpzr9hto
Sean Church informed me that intake manifold is too big for the build, If i get a race header like a kid racing and a test pipe, and a 1 layer head gasket, would i be able to rev to 9k while making power?
Old Apr 1, 2013 | 09:47 PM
GagnarTheUnruly's Avatar
Default Re: GSR build need your thoughts
The stock cat is killing you. If you can, get a high-flow cat on there, and a header with a 2.5" collector. If you need to keep stock-looking for CARB, try a JDM ITR header. With a heat shield it looks stock.
I'd get a high flow cat -- I'm not a fan of test pipes.
Old Apr 2, 2013 | 09:41 AM
98vtec's Avatar
moderator emeritus
whats so special about 9000rpm? Thats 1200 more rpm....not happening with a mild build and only subtle upgrades.
do you trust Sean church? He's done enough tuning that i'd listen to him before ANYONE on the internet. Did he give you any recommendations? Did you ask? Did you discuss any goals with him or ask for any other recommendations?
any specific questions or were you just looking for confirmation or someone to say he is wrong? Cuz you arent getting another 1200rpm of power from a little compression and a header with better design specs.
Old Apr 2, 2013 | 01:30 PM
rza619's Avatar
here is the video of the person i bought the motor from... he is making power up to 9k rpm with crower 403, only changes i made are Crower stage 2 cams, and i have a cat and he does not...
Old Apr 2, 2013 | 04:01 PM
negusjuda's Avatar
that motor seemed to peak at around 7700 rpm or so if im not mistaken notice the arc where the power started to drop it wasnt making power to 9k rpm
Old Apr 2, 2013 | 05:28 PM
rza619's Avatar
His dyno or my dyno, yeah i know mine died at 7700, but his seems to climb all the way to 9000
Old Apr 2, 2013 | 05:39 PM
98vtec's Avatar
moderator emeritus
Climbing means making more power. His stops making more power before 8000 which means it peaks there. It does appear to carry power better than yours tho
Old Apr 2, 2013 | 05:52 PM
DazeMS's Avatar
if your referring to the victor X.. I feel the same as sean church. that manifold was not meant for N/A motors like yours. The Performer X manifold IS better suited for your motor.. goodluck
Old Apr 2, 2013 | 06:13 PM
rza619's Avatar
I have the JG edelbrock manifold the 1st gen
Old Apr 2, 2013 | 06:36 PM
DazeMS's Avatar
https://honda-tech.com/forums/tech-misc-15/deep-thoughts-intake-manifold-design-214097/
and
https://honda-tech.com/forums/tech-misc-15/jg-edelbrock-intake-manifold-270591/
Old Apr 23, 2013 | 08:01 PM
rza619's Avatar
update with some more numbers
got a skunk 2 manifold instead of the Edelbrock
Tri y rep header
3 Inch type R intake
and deleted my cat
and heres the new graph
https://www.box.com/s/qouv6oupbse5eq57p7u6
210 WHP with 150 TQ should be 200 WHP on the dyno jet
Old Apr 23, 2013 | 08:24 PM
98vtec's Avatar
moderator emeritus
Looks like a fun car
Old Apr 23, 2013 | 09:27 PM
Rocket's Avatar
I agree with Church re the Victor X IM. That was designed for short duration camshafts and boost applications. The new Skunk IMs have Cosworth style design. If you are patient Blox might make Cosworth style IM.
Old Apr 24, 2013 | 12:18 AM
koczeka's Avatar
Plus get rid of those RCs and get some RDX or Bosch injector (like ID). Big gains U will see.
Old Apr 24, 2013 | 04:20 AM
DDTECH's Avatar
A better spray pattern should easily help with whp gains across the board.
I would also recommend a PerformerX or a modded pX manifold over a skunk2 / Victor for this setup.
Old Apr 26, 2013 | 06:07 PM
rza619's Avatar
so RDX injectors? what else can i do to increase power rather then bigger cams
Old Apr 27, 2013 | 05:53 PM
fandsmachine's Avatar
Velocity stack makes a difference Id also Iisolate your filter/vstack with sheetmetal to isolate heat and get colder air. Id also do a hytech replica header and do header wrap. Skunk2 pro 2's are good cams if you decide to change cams
thenoxus1
24
May 11, 2012 06:12 AM
hondaclassifieds
Mar 5, 2009 12:53 PM
type r corey
May 14, 2006 09:00 AM
methodz55
Feb 12, 2006 12:44 PM
