additional transmission support mount/bracket
Old Mar 31, 2013 | 10:09 PM
flatblack-h22's Avatar
Default additional transmission support mount/bracket
i need a to get a piece like this made, and was wondering what i should buy for the project.
i have 0 knowledge in this field, so i was looking for suggestions.
Old Apr 1, 2013 | 03:51 AM
that-guy's Avatar
Default Re: additional transmission support mount/bracket
is what is pictured not yours??? i would say get some 1/8"-1/4" mild steel plate, get some dimensions, and find a sheet metal shop that will bend it up for you
Old Apr 1, 2013 | 08:36 AM
SovXietday's Avatar
Don't bother, this piece is rather poorly engineered and will flex considerably more than a standard mount.
Old Apr 1, 2013 | 08:45 AM
that-guy's Avatar
that was my thought as well...
Old Apr 1, 2013 | 11:11 AM
vtechjunkie's Avatar
This particular piece isnt well engineered, but I think it could be done better. I would go a little thicker(3/16 maybe) and use some gussets in the bends. Where it is a "supplemental brace", I think you could do it well enough with the a little thought. Why do you need it though? Is your trans bracket broken? There might be a better fix is all, I'm thinking.
Old Apr 1, 2013 | 01:23 PM
no its a picture i found online
would this be a little bit better?
my trans is held up by only the two top bolts that i had to drill and tap. a few people had their tran break off from where they tapped it before. (click image is huge) i want a piece of mind with the two bolts on the bottom to help hold it. the motor in its original car, is bolted to a cradle with 4 bolts on the bottom of the tran.
Old Apr 1, 2013 | 03:08 PM
I think that looks much better, but I would still worry about it flexing from the bottom, where you have it bolted on. I would throw a couple more gusetts down there.
Old Apr 1, 2013 | 03:21 PM
SovXietday's Avatar
Understand that both of these designs are more or less supporting the weight by the two bolts. The lower two bolts are "bolted in" but are not adding to the actual structure because the that long 1/8" piece can deflect so much.
I would either:
A) C channel that entire lower piece at the very least. Better yet, something like rollcage spec tubing bent accordingly depending on how much room you have from the frame rail.
B) Make a 2nd mount with tubing or pretty thick stock that uses the lower torque mount location on the bottom of the frame rail as a mounting point instead of trying to tie it all into one mount directly.
Striker325
Mar 28, 2014 04:53 PM
93JDM_H22
Jul 1, 2010 12:04 AM
mercutio_07
Mar 19, 2008 04:35 PM
SQ is the SQUAD
Welding / Fabrication
Nov 15, 2005 07:12 PM
S13 slide
Oct 14, 2002 10:07 PM
