A/c delete question
I'm deleting my a/c on my 92 hatch I have everything off but there is a bracket with a relay by the driver side headlight that runs from the a/c condenser to the wire harness on the passenger side. Can I remove this and still have my fan on my radiator work?
What car? Those connectors shouldnt have anything to do with the Radiator... I just took out my A/C yesterday. Just a connecter to the AC Fan, compressor, condenser.
Ok.. It's a 1992 civic si hatch I followed the connector the relay goes to the fan on the condenser did you take yours off? I just didn't want to take it off and fu*k up my other fan
I disconnected the connector to the A/C fan and ziptied the wires to the headlight harness. Make sure you connect the ground wire to the compressor somewhere around the headlight. Also it is advised to leave the A/C compressor bracket bolted onto the block because if you remove it you will no longer have a lower torque mount and your engine could possibly fall down to that side.
