93 del sol trunk liner?
Old Mar 30, 2013 | 08:55 PM
93 del sol si2's Avatar
Default 93 del sol trunk liner?
looking for one. I think 94,95,96,97 fits too? (carpeted trunk liner with thick cardboard on bottom, carpet on top). thanks, Kevin. postal code is n8x 1b1, Ontario,Canada. Paypal.
Old Mar 30, 2013 | 09:05 PM
B_Swapped93's Avatar
Default Re: 93 del sol trunk liner?
this belongs in the market place not the tech section. don't go giving out you'r postal code either btw...go to a pick n pull and get said carpet liner
Old Mar 31, 2013 | 03:57 AM
belairbrian's Avatar
OP, I just ran into the same problem. Mine was warped. I managed to get it measured and drew out a diagram of it. went to Lowe's and got a piece of hardboard, aka masonite.
I was able to reuse my carpet, but it is fairly easy to buy a roll of trunk carpet at a parts store if you need to.
I kept my drawings and could post them as a pdf if you want to go the DIY route.
From what I have seen most of the ones in the salvage yard are unusable.
Old Apr 3, 2013 | 08:34 PM
please brian? thx, pm on the way
Old Apr 5, 2013 | 09:36 PM
here is the drawing. The board is symmetrical so i only show measurements on one side. Measurements for other side are the same
File Type: pdf
Roosterjd
10
Apr 22, 2016 12:56 PM
bochekmeout
Mar 7, 2014 11:57 AM
grinch559
May 23, 2012 07:05 PM
Sonia's Driver
Jan 19, 2011 05:37 AM
