need help- 91 dx
Old Oct 22, 2002 | 12:00 PM
11secdx's Avatar
Default need help- 91 dx
my 91 dx hatch is running rough. it throws code 16( fuel injector). i have changed out the injectors, changed out the ecu. it runs rough, spits sputters, no smoke, and after i drive it for a little while(10 min.) and cut it off, it has a hard time starting back up, it just turns over.
Old Oct 22, 2002 | 03:36 PM
Perfectionist's Avatar
Default Re: need help- 91 dx (11secdx)
The code 16 is the result of a break in the electrical circuit for the injectors. Basically, ignition switch-main relay-injector resistors-injector coils-ECU, plus all the wires between them. I would check out the main relay first.
Old Oct 22, 2002 | 04:51 PM
11secdx's Avatar
Default Re: need help- 91 dx (Perfectionist)
i had a 90 si, the main relay went out on it. i was wondering about it. thanks
tuningrookie
Dec 22, 2006 07:53 AM
4ghatch
Apr 26, 2003 07:13 AM
4ghatch
Jan 16, 2003 05:54 AM
wannab20hatch
Oct 4, 2002 11:00 AM
