Honda CR-V & Element 2WD & 4WD Element & CR-V
crv automatic transmission fluid advice needed
Old Mar 30, 2013 | 01:35 PM
chazt's Avatar
Default crv automatic transmission fluid advice needed
i want to change transmission fluid in my automatic crv and do i have to use honda brand or can i use another brand im thinking of cost if i do a triple change to completely renew fluid as local honda dealer is taking around £15 a litre
thanks
Old Mar 30, 2013 | 01:47 PM
qwrty's Avatar
Default Re: crv automatic transmission fluid advice needed
oem!!
itll save you tons of money later... one of the V i bought from a private owner replaced all fluids before
selling the V to me, after a few miles i started feeling the erratic or sometimes sudden change or
disengage of gears... i called him back and told me that he just went to a local lube shop and had the
V change all fluids there, long story short... i had to pump out/siphon the whole atf 2-3x w/ the oem
fluids to remove all trace of the different atf!
Old Mar 30, 2013 | 01:53 PM
chazt's Avatar
thanks for advice
Old Mar 30, 2013 | 02:04 PM
slowesteg's Avatar
stick with OEM.
Old Mar 30, 2013 | 06:26 PM
rkpatt's Avatar
Alternatively, I have used Valvolene Maxlife ATF in Hondas for years and not had any problems. I have used both the 3X drain and fill method and also the drain then fill flushing though cooler lines . Either way, I do at least at 1/2 the interval than the owners manual recommends.
Old Mar 31, 2013 | 04:25 AM
chazt's Avatar
thanks to all replies will stick to oem fluid
Old Mar 31, 2013 | 04:49 AM
G35zay's Avatar
I just change my tranny nd my differential fluid last weekend nd I use oem. Nd price wise is not a big difference nd u kno at the end of the day is going to benefit the life of our crv
Old Apr 6, 2013 | 02:26 AM
davidbloom2013's Avatar
It’s recommended to use genuine Honda oil even for the manual transmission so, my advice is to use Honda AMF. And let me tell you that replaced fluid will always be black as a 1x drain and fill doesn’t actually drain all the fluid from the torque converter. That’s why Honda uses a 3x drain and fills to attempt to change all the fluid.
ManInBlack
Honda Civic (2006 - 2015)
Jul 15, 2013 03:04 PM
Jaydeep
Honda Civic (2001 - 2005)
13
Jun 23, 2011 12:33 PM
icanbrkurhrt
Mar 3, 2010 03:15 PM
tom48
Jul 14, 2008 08:30 PM
Matt00
Sep 26, 2005 01:50 PM
