Suspension & Brakes Theory, alignment, spring rates....
PITA LCA BOLTS!
Old Mar 30, 2013 | 01:15 PM
rollinhonda3's Avatar
Default PITA LCA BOLTS!
so ive got a 97 civic sedan and im trying to put my coil overs on. well the passenger side strut bolt wouldnt come out but the other two holding the lca on did so i dropped the lca with strut attached and put aftermarket lca on with new coilovers but now the driver side i got the inside lca bolt off but the one that connects to the trailing arm turn 1/4 in and stops and impact wont turn it any more. ive tightend and loosened about 100 times still no luck and its drenched in pb blaster! anyone have any ideas? and what do i do if the head snaps off?
Old Mar 30, 2013 | 01:34 PM
Default Re: PITA LCA BOLTS!
the bolt is turning slight left and rite but like i said only 1/4 turn and if i loosen it with a rachet i can feel it like bounce kinda like im twisting rubber if that makes sense
Old Mar 30, 2013 | 01:35 PM
grumblemarc's Avatar
The Grumpiest
Yeah. It's rusted to the sleeve in the bushing.
Old Mar 30, 2013 | 03:06 PM
yes, ive got in unthreaded but the bolt of course wont slide out because the sleeve is stuck any ideas? btw this is the bolt that connects the lca to the trailing arm so closest one to the tire
Old Mar 30, 2013 | 03:42 PM
The Grumpiest
Burn it out.
Old Mar 30, 2013 | 05:29 PM
i got it out thanks! had to cut it
civexspeedy
Suspension & Brakes
15
Feb 19, 2014 07:30 PM
IAcivicEK
Jul 1, 2007 07:37 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
flip b18b
Jun 28, 2004 10:31 PM
b18bvudoo
Aug 16, 2001 08:14 AM
