Teggy cluster in 91 efsi
So you have an electronic VSS in the transmission right? Not the stock one.
You have 3 wires at the plug right?
You have the right wire going to the right place at the cluster right?
That should do it.
That should do it.
ya thats a fun swap. got mine working in my ef but it took a while. where do you have the three wires from the vss going currently and are you sure which each one of the vss wires does?
you can pm me for some specifics if you need.
if you wanna swap numbers i can take some pictures of mine and show you how i did mine.
oh and which pin out list are you using for the swap? there are quite a few floating around the net with very slight variations.
Ok so I have the ground grounded. Then I have the middle for the signal which I have running to the orange wire at the cluster and also to the red/yellow wire at ecu and the power to the black and yellow at the cluster. And yes lol the electronic vss is in. I used every diagram I can find
4LugR
Jan 22, 2011 07:02 PM
ant$missShift
12
Jun 8, 2007 06:02 PM
