Compression vs Flare Type AN Adapters
Old Mar 30, 2013 | 11:05 AM
BC_Garage's Avatar
Default Compression vs Flare Type AN Adapters
I have an EK that I am getting ready to do a GSR swap in. I am planning on convering the OEM fuel feed and return lines to braided hoses with AN fittings. I am just converting the lines in the engine bay. I know there are two ways to do this on a feed and my question is which is better.
1. -6 AN to 5/16ths compression adapter
2. Flare type adapter. Not completely 100% on this but would this one require a -5 nut and -5 sleeve with a -5 to -6 reducer? Or do they sell -6 to 5/16ths flare type adapters?
Thanks.
Old Mar 31, 2013 | 07:29 AM
BC_Garage's Avatar
Default Re: Compression vs Flare Type AN Adapters
Bump
Old Apr 1, 2013 | 07:36 AM
accorse07's Avatar
Earl's actually sells -6 to 5/16 flare adapters. Make sure to get a close quarters pipe cutter as well as extra brass flares. If you mess up just once and do not have the pipe cutter handy or extra brass flare o-rings...the job becomes an ordeal. Oh and make sure to get the flared fitting on and test it for leaks before you cut down your AN lines.
Old Apr 1, 2013 | 09:24 AM
BC_Garage's Avatar
So are the flares better than using the compression fittings? The compression fittings seem less likely for problems since there is no flaring involved?
Old Apr 1, 2013 | 10:39 AM
accorse07's Avatar
The AN flare adapter is a compression fitting. I believe you may be getting mixed up in terminology.
Old Apr 1, 2013 | 12:30 PM
BC_Garage's Avatar
I'm talking about the type that doesn't require flaring. Earls calls it a compression tubing adapter that uses a ferrule, on the inside instead of the sleeve.
Old Apr 1, 2013 | 12:39 PM
BC_Garage's Avatar
This is an example of the one with a compression fitting.
Old Apr 2, 2013 | 12:44 AM
d15bvtechatch's Avatar
get the compression fitting, that's badass, i used the flare adapter and it was a pain! took me like 5 re-cut/flares to get no leak.
Old Apr 2, 2013 | 01:01 AM
zcegdx's Avatar
Ive probably sold 100 fuel tuck kits with the compression setup.
Never had a single complaint. Ranging from stock to 600+ hp setups
Old Apr 2, 2013 | 08:24 AM
BC_Garage's Avatar
Okay great that's much easier than using a - 5 and then a - 5 to - 6 reducer. The compression comes in a - 6 to 5/16ths.do the flare type come in a - 6 to 5/16ths or you have to use the reducer?
Old Apr 2, 2013 | 10:37 AM
zcegdx's Avatar
The -6 isnt the same size as 5/16 thats why it needs the -5 then step up to -6.
Its easier and faster to go compression. If you need a kit or help shoot me a message and i can explain anything you need
Old Apr 2, 2013 | 12:19 PM
BC_Garage's Avatar
Thanks will do.
DavidR
Welding / Fabrication
Mar 14, 2009 10:00 AM
YiNYaNg
12
Oct 18, 2006 04:15 AM
ScubaStevo80
Oct 15, 2003 10:03 PM
Convoy
Feb 28, 2003 08:57 AM
