ZC trouble
So I picked up a couple CRXs trying to make one out of the two of them. 89 and a 90'. Both have ZCs. Intakes appear to be different...the vacuum lines hook up differently. The engine I'm trying to run is leaking oil out the header. From the research I've done I think it's the exhaust valve seal. I was hoping to just switch the engines heads to avoid trying to change the valves myself.
I believe both engines are 3rd gen ZC (matching valve covers)
Are the heads interchangeable?!
Please throw this rookie a bone
Yeah they're interchangeable. Maybe throw up a pic of them if you want more confirmation. As long as you're not trying to mix sohc and dohc, the zc heads will swap fine as long as you swap all the OBD related gear with it.
Make life easy and use the IM off of the old car too.
Before* fluxuating between 1500-2500. All the vacuum lines are hooked up correctly and I've inspected both TPS and IACV both seem to be operating. I'm stumped as to what the issue is. I haven't reset the Ecu (don't know how) Ecu has 88' integra written on it.
That ECU is a PG7, which is the closest thing you'll get to the ECU the motor was supposed to come with (pm7). Disconnect your negative battery terminal for 10 seconds, and the ECU will clear its codes. It's not going to have any effect on your idle though. Sort out your vacuum issues and it should be sweet.
