d16y8 worth buliding or build a bseires motor
I new to the hole Import Seen and was wondering if anyone could give me so gidence. I looking to build a motor for my eg I have a d16y8 block with a po8-3 head already I'm wondering if this is worth building or go to b16 or b18. I'm looking to get around 300 to 350hp.
you're not getting that kind of power out of either engine without boost. it's easier, relatively, with a b series but you can forget any notions of keeping it streetable.
I have about 3000 just trying to get an idea of what I'm able to do with it to get the best bang for my buck. I'm use to v8 is.300 Hp a little to much for a street car/track car
browse through all motor dyno post adn note the 1/4 mile times with those motors.
and then go to boosted section and see what power vs 1/4 mile times they have. that should give you an idea about what you want to do.
1500-2500 will get you a gsr with boltons and tune will be around 170-180WHP
3000-5000 will get you a jdm itr or usdm itr motor with tune can be between 180-205WHP
b20vtec could be a bit more power for 2000-3000gs but it has to be built and have the pars that work together best.
if you do want to build it take my advice( from experience lol) and find a setup that is within your budget and has the power that you want and copy it.nothing wrong with that to do your first uild that way you know what is what.
unless he can get it within his 3000 budget
you will be disapointed with a single cam.
and possibly surprised that a gsr or ITR can keep up with a good amount of american backyard built so called muscle cars (which are equivalent of riceburner hondas that are also built in the backyard with no proper tools or tune)
probably not gonna get close to properly built american cars tho unless they cant drive...
theres a guy here with a gsr that pushed it into high 12s
and plenty of other great builds to look at just take few weeks to browse through before making any kind of fast and furious part buying decisions.
Thanks for all the info raver I'm gathering as much info as I can before I buy anything as I have been bunred before by not having everything together when starting a build and lots of money
thanks for your thoughts
Listen to Raver, he has a lot of useful info. If I were on your 3000$ budget I would find myself a nice GSR swap and build the head correctly, leaving the block stock assuming it is healthy. If done right you could see 195~210 whp or mid to high 12s 1/4 mile if its in a half way light chassis. You can go about your build however you want, but in the end this was a very cost effective way for me to get good power.
have any idea were to look for a motor i,ve looked on ebay and cragislist and every body want's stuiped money for there gsr are i only seen them for 3500 to 4800 i've just started to look on this site but haven't found anything yet
luv2splooge
Sep 16, 2010 10:27 PM
