Mini Me Swap HELP
Old Mar 29, 2013 | 03:53 PM
MySiIsRed's Avatar
Default Mini Me Swap HELP
Okay ive been reading and cant find my motor being swapped. Here is what I have so far
d15b7 block
d16z6 head
p28 ecu
What else do I need? Hopefully not spending over 200 more, What timing belt do i need? and do I need distributor? Wiring hearness? What all Do I need? Thanks
Old Mar 29, 2013 | 04:02 PM
fame45's Avatar
Default Re: Mini Me Swap HELP
http://lmgtfy.com/?q=mini+me+swap+
Old Mar 29, 2013 | 04:33 PM
MySiIsRed's Avatar
Is that everything i need?
Old Mar 29, 2013 | 04:37 PM
B_Swapped93's Avatar
^that's the offical write up/DIY so yes.
Old Mar 29, 2013 | 04:39 PM
MySiIsRed's Avatar
Can I do everything without the head, and ecu for 200?
Old Mar 29, 2013 | 04:49 PM
what ? i thought you had the head. you should be able stay under 200 assuming you have the head allready.
Old Mar 29, 2013 | 06:41 PM
MySiIsRed's Avatar
Yeah I got the head and Ecu I just need the otherr parts.
Old Mar 29, 2013 | 06:43 PM
other parts being the intake+TB and the header ?
Old Mar 29, 2013 | 06:48 PM
MySiIsRed's Avatar
No like distributor, water pump, timing belt. all that
Old Mar 29, 2013 | 06:59 PM
don't know if you'll be able to stay under 200 for all those little things.
superfly662001
18
Nov 17, 2008 07:52 PM
tinymotor22
Apr 1, 2008 07:14 PM
duckmanEG
Nov 5, 2004 11:25 AM
ss20gsr
Feb 7, 2004 08:20 PM
