Release Bearing
Old Mar 28, 2013 | 10:52 PM
H22_CB7_JAY's Avatar
Default Release Bearing
Hello all,
Is there anyway I can get grease to the Release Bearing? Mine is making ALOT of noise! Just wanna know if I can get by with greasing it (and not dropping the tranny) Maybe through the Flywheel timing hole? Just unsure of how to go about doing it.
Old Mar 28, 2013 | 11:47 PM
holmesnmanny's Avatar
Default Re: Release Bearing
What kind of noise is it making ? Does it stop doing it when you lightly press the clutch in ?
Old Mar 29, 2013 | 11:09 PM
Yes sir
Old Mar 29, 2013 | 11:38 PM
It's probably you just need to regrease the ball joint piece of the slave cylinder. Take off the two bolts that go to it...i think 10mm or 12mm.. remove the slave and apply axle grease to the ball piece. Then put it back on. The noise should go away.
Old Mar 30, 2013 | 01:13 AM
That's not it. My slave cylinder is Brand new...
Old Mar 30, 2013 | 01:15 AM
I know its the Release Bearing. I need to know how I can get grease to it, without dropping the tranny.. I'm hoping Its possible.
Old Mar 30, 2013 | 01:48 AM
I'm not saying your slave cylinder is bad or there is anything wrong with it. It's up to you if you want to do what I said.
Old Mar 30, 2013 | 03:46 AM
I'm talking about the two bolts that hold the slave cylinder to the tranny not disconnect the slave cylinder from the system altogether.
Old Mar 30, 2013 | 05:43 AM
NZXTInerTia's Avatar
The fork that the slave cylinder pushes (which pushes the release bearing) rides on a ball. He is telling you to grease that ball.
Old Mar 31, 2013 | 12:02 AM
Okay? I'll try that..
Old Mar 31, 2013 | 12:18 PM
Hidenplanvew's Avatar
There is no way to grease your throw out bearing only replace it. You might as well do a clutch too while in there
Old Mar 31, 2013 | 06:50 PM
nus_dogg's Avatar
x2!
Old Mar 31, 2013 | 10:44 PM
1) his problem isn't the throwout bearing
2) nobody is saying to grease the throwout bearing
Old Mar 31, 2013 | 11:06 PM
This is taken straight out of my Helms. It's up to you if you want to grease where it says to grease. I'm not posting in this thread anymore.
http://i365.photobucket.com/albums/o...ps2f37278a.jpg
Old Apr 1, 2013 | 07:14 AM
hondamark35's Avatar
If you're correct in your assesment, then no it's not possible. the transmission will need to come out in order to attempt adding grease to the bearing. and, on that, no you cannot service these bearings. if it's making noise it needs to be replaced. grease will not fix it.
and like Holmesnmanny has been saying, grease the pivots before you try to spend any time with the bearing.
Old Apr 2, 2013 | 03:28 AM
My clutch is brand new, in fact I just finished my transmission swap/clutch job.
My sincere apologies to holmesnmanny who was absolutely right! I was completely oblivious to what you were trying to suggest, until I seen the picture. Thanks a ton dude.
Old Apr 2, 2013 | 03:29 AM
This is the correct fix for this problem.
Old Apr 2, 2013 | 11:18 PM
no problem at all
red96cobra
Transmission & Drivetrain
Dec 8, 2009 10:58 PM
SiRlos
18
Sep 24, 2007 11:41 AM
Paluce
Jul 20, 2007 10:26 AM
trooper0641
Jan 4, 2005 01:34 AM
ritm
May 30, 2003 05:07 PM
