99 Civic 3 wire to 2 wire idle control valve help
just hooked up my performer x manifold up with the 2 wire idle control valve. picked up the connector from the junk yard, i should be able to wire it up and leave the orange wire disconnected ?, or do i have to move pins around ? just finished putting the motor back in the car and trying to get it to idle right, anyone know anything?
[QUOTdokyden;48621391]you have to move pins around. but you can't use a 2 wire in place of a 3 wire on the same ecu.[/QUOTE]
What do you mean? The Edelbrock mani is made door a 2 wire. So I'm not going to be able to use it without changing the computer?
