Honda CR-V & Element 2WD & 4WD Element & CR-V
Gen 1 CRV not starting
Old Mar 28, 2013 | 11:05 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Gen 1 CRV not starting
Picked up a 99 CRV 5 speed as a project, was told it had a bad starter. Pulled the starter, had it tested 3 times in a row at the same place. Passed every time. Put a brand new battery in. Two days ago, it turned over a couple times slowly, noticed a burning smell from the starter. Today, tried it again after dropping a spoonful of ATF down each plug tube, now it is just one click, but a hard click. Can see the motor move with the click, but does not even turn over. Any advice? Hate throwing parts at problems. Thanks
Old Mar 28, 2013 | 11:12 AM
LDForget's Avatar
Default Re: Gen 1 CRV not starting
a starter can turn with no load, but as soon as a load is applied (the motor, or a 2x4 jammed into it) it wont have the torque to turn it. Put the starter in a vise, jump it with a battery or booster pack, and jam a 2x4 in it. if it still turns, then you know its good.
Old Mar 28, 2013 | 01:42 PM
ill give that a shot, id hate to waste the $150 on a new one. any other ideas?
Old Mar 29, 2013 | 05:51 AM
dogbiscuit's Avatar
You could always check junkyards for old V's and maybe get one that way. would be a lot cheaper than $150 prolly less than $50
Old Mar 29, 2013 | 07:04 AM
im going to pull mine apart and replace points, etc. ill post up results.
Old Apr 2, 2013 | 07:51 PM
new starter, same problem
Old Apr 2, 2013 | 08:24 PM
willie_winnings's Avatar
if u can post a video of u cranking the crv so I can hear whats it doin I can def give u some help
Old Apr 2, 2013 | 09:02 PM
its just one loud click in the engine bay
big.turbo.daddy
Jun 23, 2015 06:34 PM
crxaddikt
Dec 5, 2007 12:31 PM
Integra_drk
Dec 27, 2006 10:19 AM
Touge Tuning
May 3, 2006 11:14 AM
IN2VTEC
Apr 16, 2004 03:00 PM
