OBD1 Check engine code opinion?
Old Mar 27, 2013 | 09:43 AM
Wilka's Avatar
Default OBD1 Check engine code opinion?
I got a check engine light on the way home, only happens in high rpms, if anyone can give me the code and maybe some suggestions, looking for a second opinion..
Old Mar 27, 2013 | 09:45 AM
Wilka's Avatar
Default Re: OBD1 Check engine code opinion?
Intake air sensor?
Old Mar 27, 2013 | 09:48 AM
B_Swapped93's Avatar
jump the connecter with the key in th 2(II) postion. i couldn't see exactly how many blinks that was. i'll say 10 which would be the IAT sensor but was to hard to see from the vid.
Old Mar 27, 2013 | 09:52 AM
Wilka's Avatar
I tried the samething, I even tried to get my mom to count, it blinks like that everytime though, I tried it 3 times
Old Mar 27, 2013 | 09:54 AM
ok well it's forsure 10 i watched it a few more times. what car/engine do you have didn't say in you'r OP
Old Mar 27, 2013 | 09:57 AM
Wilka's Avatar
94 ex coupe with 94 obd 1 gsr
Old Mar 27, 2013 | 09:59 AM
assuming you have the stock gsr intake mani. here's where you'll find it. see if it came lose or something small like that
Old Mar 27, 2013 | 10:02 AM
Wilka's Avatar
Dude I notice your the only one who really tries to help on my last couple posts lol thanks, and I just got tuned.
Old Mar 27, 2013 | 10:04 AM
Wilka's Avatar
Guess I need to hit up my local junk yard or see how much autozone is gunna try to rob me for.
Old Mar 27, 2013 | 10:08 AM
Junk yard:they'll most likly let you have it. or at most ask 1$ for it, you can clean it give that a try then re-set the ecu. if not replace it.
Old Mar 27, 2013 | 10:12 AM
Wilka's Avatar
Gunna go outside with my philips now lol
Old Mar 28, 2013 | 07:19 AM
94EG8's Avatar
Seagull Management
I can't quite figure out the first code. The second code is 8 though (TDC sensor in the distributor)
Neither code is for IAT though. IAT (code 10) is a single long blink.
Old Mar 28, 2013 | 10:53 AM
Wilka's Avatar
So the new distributor is bad? Its brand new oem one.
Old Mar 28, 2013 | 10:54 AM
Wilka's Avatar
I'll upload the new video, I replaced IAT
Old Mar 28, 2013 | 10:55 AM
Wilka's Avatar
Old Mar 28, 2013 | 11:09 AM
Wilka's Avatar
Sorry for not getting it completely the first time I couldn't keep the pin in the service connector lol
Old Mar 28, 2013 | 11:25 AM
Wilka's Avatar
So what I've gathered in my opinion is code 8, which is a little hard to believe in a brand new distributor, bought brand new in feb and less than 300 miles on it, any suggestions?
Old Mar 29, 2013 | 10:00 AM
Wilka's Avatar
I changed the dizzy and the code went away, just the monkeys at autozone forgot to put a rotor under their new cap and everything and I got a p73 or td 66 dizzy which comes from a type r I believe, not that it makes a difference but I thought it was cool
Old Mar 29, 2013 | 10:14 AM
94EG8's Avatar
Seagull Management
If it was an aftermarket distributor that wouldn't surprise me at all. They're just not well made at all. If it was a real OEM Honda one then yes I'd be very surprised.
Old Mar 29, 2013 | 03:05 PM
Former User's Avatar
Also, you don't need the engine running to pull the codes.
1) Jump service connector.
2) Turn key to ON(II).
3) Post video that shows the blinking codes until the pattern repeats.
4) Reset the ECU to clear codes.
5) Drive car or run engine until CEL turns on and stays on.
6) Pull CEL codes again.
7) Post all codes that repeat in both tests.
76 camaro car
Dec 6, 2011 09:16 AM
Dman03GT
Oct 31, 2008 07:39 PM
sing
May 17, 2007 02:56 PM
Scream'nSol
Oct 8, 2002 02:01 PM
