Car won't start after attempting to wire reverse lights...?
Well, like the title says;
I went to go wire up my reverse lights as per the 5spd swap thread's directions, and now my car won't start.
I hear the fuel pump priming when I turn the key to ACC, and also delivering fuel when I attempt to crank it. However, nothing else happens at all. No click, no crank, nothing.
PLEASE HELP! This is my daily driver!
Never had an issue before. I tried to explain the issue as best as I could in the first post, those are the only clues I have as to what may be wrong...
Edit: Overlooked the starter signal wire. Will check within the hour.
Dont overlook to wiring needed for the a/t shifter. Not sure of the exact procedure, but something has to be done to make it think its always in park.
UPDATE: It WAS the starter signal wire
Such a simple thing that I overlooked... I was clipping and unclipping harnesses, following wires, pulling fuses... and it was right in front of my face smh. Big interview tomorrow, I'd be screwed if I couldn't get her up and running! Thanks to all for their input
Junior1988
Sep 5, 2018 08:52 AM
EFjoe91
Apr 30, 2014 05:49 AM
EcivicG
11
Jun 23, 2008 03:40 PM
