JDM D15B Vtec
IIRC the D-series springs are all the same.
You can't use the VX tensioner btw. The only one that works is the D15B Vtec tensioner. Some guys run a Z6 belt with the VX/Si tensioner. When I did mine I just kept the original tensioner, they really don't go bad very often, but inspect it when it's apart and make sure the bearing feels and sounds good.
Well dang I dont even have that any more either... I thought the vx tensioner would work its just slightly bigger. Damn... Well any leads on where I can order one or get one...
Basically I got a JDM D15B and I decided to do a headgasket and timing belt change prior to installing it... and I misplaced that stuff
Also the timing cover is there any that are interchangable? Thanks alot for the information
D15Z1/D16Z6 both work for all the plastic timing covers on that engine.
Since you already have the tensioner at hand, might as well give it a try. I used a D15Z4 tensioner on my D15B and it was a little bigger but the timing belt fits. There is very little slack in the belt though and I had to pull the tensioner all the way down to insert the belt. 20K km now and there is still no sign of trouble.
Here's a thread that might help
http://civic-eg.com/viewtopic.php?t=13341
http://www.d-series.org/forums/gener...ent-parts.html
And a website that sells some JDM Honda parts
http://www.autodynamics-honda.com/belttensioners.html
well thank you for the help.
I think I may have found the timing belt kit I need. But where I am confused slightly is it says D15B 3 stage Vtec.. where mine only has one and its OBD1
but I think this is what I need
http://store.autodynamics-honda.com/hop2ap2jtibe.html
I think I may have found the timing belt kit I need. But where I am confused slightly is it says D15B 3 stage Vtec.. where mine only has one and its OBD1but I think this is what I need
Kush2Slow
Mar 16, 2014 10:59 PM
HTn00b
Nov 14, 2006 06:50 PM
nicehatchy
Mar 12, 2006 02:12 PM
foesicks
Jun 2, 2003 05:15 PM
