Accidentally seperated knock sensor
Old Oct 22, 2002 | 09:27 AM
SC94DB8's Avatar
Default Accidentally seperated knock sensor
When pulling the plug off of the knock sensor I accidentally broke the black housing off of it.( the sensor is now in two pieces) Would it be possible to re-solder the two little connections on the inside?... or more importantly, would the sensor work correctly if i did this? Thanks in advance everyone.
Jason
Old Oct 22, 2002 | 11:16 AM
BigMoose's Avatar
Default Re: Accidentally seperated knock sensor (SC94DB8)
Jason,
Thought I would share a thought...............
Considering the critical nature of the knock sensor, would you really want to take the risk of repair? Do you have an OBD-II Scanner to verify your repair?
Without a picture, it would be difficult to give a difinitive answer on the repair of your sensor damage. You need to balance the cost of a new sensor versus the cost of the engine detonating without proper feedback and control.
Regards,
BigMoose
hoezee
Oct 6, 2008 10:40 AM
S2K Luver
Mid-Atlantic (Sales)
Mar 18, 2007 05:46 PM
