Transmission & Drivetrain Gearboxes, Differentials, Clutches
Torque converter stall speed
Old Mar 23, 2013 | 05:25 PM
MHBuckley's Avatar
Default Torque converter stall speed
I have a 93 accord SE. What is the factory specification for the torque converter stall speed? Also, the torque converter clutch is staying locked up in drive and reverse causing shuddering, vibration, shaking in the steering wheel. Have tested for tcc solenoid being stuck on, operation is normal. Suspect clutch piston getting fluid pressure from an internal leak in the converter. Any one have any knowledge about the internal workings of this converter or trans to cause this? Seen this problem before?
Jmb106jr
Jun 8, 2015 07:38 AM
knucklehead11
May 28, 2006 11:34 PM
mrdeadman
Jul 27, 2005 08:52 AM
dbraunsdorf
Apr 12, 2005 12:55 AM
