5th Gen Ram Air System
Old Oct 22, 2002 | 08:57 AM
trahsub's Avatar
Default 5th Gen Ram Air System
Has anyone tried this? I have a 2000 lude and I was looking at the front end design this weekend, and it looks pretty easy to make ram air system that goes from the passanger side fog light insert up to the intake cone. All I think that needs to be done is to remove the stock intake assembly and maybe trim some of the spash guards to get a tube up to the engine bay. Thoughts? Comments?
Old Oct 22, 2002 | 09:14 AM
DsITR's Avatar
Default Re: 5th Gen Ram Air System (trahsub)
I Have an Injen CAI, and that is exactlywhat it does ...not sure I really understand your ??
Old Oct 22, 2002 | 10:56 AM
dwn-shift's Avatar
I dont think a ram air system would help that much. I read somewhere that trying to do a ram air setup wouldnt do much bacause of the design of the plenum on the intake manifold.
Old Oct 22, 2002 | 11:14 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: 5th Gen Ram Air System (dwn-shift)
it doens't work, i put in on my teg from the passenger side high beam, and it sucked (well, actuallu it didn't) best idea, just put the filter somewhere that get a lot of airflow
Old Oct 22, 2002 | 11:49 AM
osuPrelude's Avatar
It wouldn't work from what I understand. You see the run of the intake tubing can't be too long. I believe the amount of surface area that the air to encounters can't be too large. I'm assuming the air won't have enough force in some manner. However, on my old '93 dakota V6, I ran some tubing (the plastic bendy/expandable stuff from the other side of the metal circular filter housing to behind my grill, in the same manner as the factory setup. I only noticed a slight increase in power up top. Remember though, I doubled my intake capacity to the filter, rather than lengthen the run and possibly lessen the capacity. just IMHO. Peace
[Modified by osuPrelude, 8:52 PM 10/22/2002]
Old Oct 22, 2002 | 01:57 PM
714's Avatar
714
I think if you cut a hole in the hood just above the intake and put a scoop and tubing to the intake, it could work, but quite frankly I dont know chit. Just a thought
Forgot to mention the obvious aesthetic implications
[Modified by 714, 11:09 PM 10/22/2002]
Old Oct 22, 2002 | 02:00 PM
EH2DX's Avatar
don't bother. just get a cold air intake. those showed the best gains on hondas.
ram air's don't really work on our cars.
Old Oct 22, 2002 | 05:35 PM
arrrmand's Avatar
Default Re: 5th Gen Ram Air System (BB1)
i agree..i had an old short ram intake that didn't really give me any gains....only sounds. i switched later to a cai and definitely felt the gain.....not to mention a better sound.
carid
Performance
Aug 19, 2015 04:11 AM
SilverBullet_01
Feb 13, 2010 10:16 PM
G_seven
Acura TSX
Jan 31, 2008 09:50 AM
JBirch_97Prelude
Mar 26, 2007 03:02 AM
BLUE EH3
Mar 30, 2005 01:00 AM
