itr dc2 cluster in 91 ef issues.
if any one has done one can i have answers to why i cant get it to read on any of the needles. fuel, temp , and tach. idk about the speedo but that probable does not work either even thou i wired up the vss to ecu and cluster.
what does work is, back light, blinkers, hazard. and when i put power to oil,check engine, door, and ebrake thous work. but i cant get the needles to read, and i have been blowing fuses trying to fig it out .
this is what im going bye.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/gsr-cluster-pinouts-90-91-crx-pinouts-how-i-need-help-1732102/
im guessing i am getting power to the temp and fuel gauge becuase they move very little either down or up when i turn key..
also after wiring everything up, i had no power to most the lights. i had to take one power wire, connect say 4 wires to it and then run it to oil,check, ebrake to get them to work.
K2e2vin
Jan 15, 2008 04:54 PM
