can't start car
Old Mar 22, 2013 | 07:50 AM
Andyxramirez's Avatar
Default can't start car
93 del sol si d16z6 mostly stock
Recently my car hasn't been able to start. I've been having to have someone push it to be able to start it.
is it the starter? or something else?
when I try and turn it on it doesn't grind or do anything.
Please help
Old Mar 22, 2013 | 07:55 AM
xTyFighterx's Avatar
Default Re: can't start car
ya could be the starter do you know if its getting fuel? tap on the starter with a wrench or something then try and start it might just need the terminals cleaned on the starter thats all mine needed it was doing the same thing
Old Mar 22, 2013 | 08:09 AM
I'll try that thanks for the advice.
Old Mar 22, 2013 | 08:21 AM
ya or you can use a tester and test it might be the best but whatever is easier for you but if it is the starter dont go buy a new one till you at least clean the terminals off usually they are just dirty and built up with crap so do that first and if its still bad then go buy a new one
lmk the outcome or if you need more help
Old Mar 22, 2013 | 09:48 AM
Ok thanks man.
What's the best way to clean the terminals?
Old Mar 22, 2013 | 09:52 AM
prob a wire brush i assume
Old Mar 22, 2013 | 02:56 PM
ElectronBlue00's Avatar
When you say grind, do you mean crank?
Old Mar 23, 2013 | 11:33 AM
Yes.
Old Mar 23, 2013 | 11:35 AM
B_Swapped93's Avatar
that's most liklely you'r starter if you require a push to get it going but at least it starts. i'd just replace it that must be a pain to deal with.
Old Mar 23, 2013 | 11:42 AM
digitalvice's Avatar
for the price of a starter its worth the money. I paid 28 bucks for mine from a scrap yard and works like a charm.
Old Mar 23, 2013 | 11:43 AM
most likley it just needs clean mine went out and i went and bought a new one it was like 160 took my old one off and found it needed cleaned thats all but if you want deff put a new one on just trying to save you money
Old Mar 23, 2013 | 12:02 PM
You guys all seem to say the starter. I haven't had time to take it to my mechanic but when I do I'll let him know to clean it first and see if it works before he goes to buy one.
Thanks on the input.
Old Mar 23, 2013 | 12:27 PM
save some money and clean it you'r self. it's easy to remove and put back
Old Mar 23, 2013 | 12:28 PM
takes 2mins id say pretty easy to get to
Old Mar 23, 2013 | 12:33 PM
well I'm a noob lol
I recently just got into cars.
anyone got a write up?
Old Mar 23, 2013 | 12:43 PM
this is how to take it off you just need to un do the bolts that hold the poitive and negative wires and clean. if it still doesnt work then take it off put the new on
http://www.ehow.com/how_6196204_chan...del-sol-s.html
Old Mar 23, 2013 | 12:44 PM
took 2 mins to search here:
PatrickGSR94
Jan 13, 2024 05:15 AM
lxdriver
11
Aug 25, 2013 07:31 PM
JPerkMr954
Jun 9, 2013 08:51 PM
cbaber
Jan 6, 2010 05:15 AM
mistake-2
Jun 24, 2003 04:39 PM
