identifying engine help
I found a dohc VTEC motor at a scrap yard today. Still intact with header, intake mani, fuel rail and just about everything except for the throttle body. It even had the TPS and map sensor still on it.
I did however forget to identify the engine. If you guys can help me identify it with the little visual characteristics I can give thatd be cool. It is the engine with the very simple valve cover on it. Its not customizable with a wire cover or anything. If I had to guess I would say it might be a d series but I'm not positive. Any help on this would be appreciated.
Sorry for the vague description though.
Re: identifying engine help
Look at the front of the motor, near the transmission. It should be marked there. [letter][number][number][letter][number] is the general format, like D16Y7, or B18C1. It's pretty simple.
How exactly can it have the TPS if it doesn't have the TB? The TPS is on the TB.
I remember it being there. The TB must have been there then. I don't have the engine anywhere near me or else Id just look for the engine code.
Seagull Management
OP, go take picture of this or something if you want it identified. A very vague description of an engine really just wastes everyone's time. Although really the smart thing to do is just look at the stamp on the block.
Master Ninja
i thought you had a b16 in you'r car...why look at engines in a scrap yard ?. Either way look at the block stamp you should know the diff between a VTEC b series(what you have right ?) and a non vtec b or a D
OK OK obviously no one is reading the OP. I forgot to look for the badge number so I was hoping someone could identify it by description. I don't want to swap I want to buy it for cheap, rebuild it and resell it for profit.
ok does it look like you'r B16 as all honda B-series vtec engines look the same(more or lees). you must have gotten a look at the valve cover does it say DOHC VTEC ?
The Grumpiest
Wow. Instead of making people guess at it go back to the yard and actually ID it and take at least one picture. Whose phone doesn't have a camera on it nowadays?
How about get on Google and do an image search? Jeez. This whole thread was a waste of time.
1SOL2NV
10-25-2004 02:52 PM
