98 Civic B18 swap wont start
Old Mar 21, 2013 | 11:42 PM
hookahpro's Avatar
Icon2 98 Civic B18 swap wont start
Recently did a tranny swap a couple weeks ago, and car has been running great. Now it wouldnt start today, figured it was the battery, so i replaced it and still nothing. Starter just clicks alot when turning the key. Was told to check if the headlights dim when turning the key and they dont. (could be ignition switch i was told). Then decided to Jump the starter with the key in the on position, and sparks of course, but still just the clicking sound. I had my wife try with my hood popped so i could see if anything else is happening and the ground wire from the car to the tranny had a spark come off it. If anyone knows what could be the problem please if anyone can help! Also just to add, the only recent things ive done is today i replaced a Coolant hose cause it had a hole.
Old Mar 22, 2013 | 03:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 98 Civic B18 swap wont start
Recheck, clean and tighten all of your grounds and check all the wires going to the starter. It's either that or a bad starter.
Old Mar 22, 2013 | 10:20 AM
hookahpro's Avatar
Picking up a new starter today. Would the ignition switch be bad at the same exact time since the headlights are not dimming down when trying to start?
Old Mar 22, 2013 | 10:42 AM
kyden's Avatar
headlights dimming have nothing to do with the ignition switch. the dimming is from the battery drain of the starter.
Old Mar 22, 2013 | 10:59 AM
mechanix619's Avatar
I wouldn't recommend throwing money at parts until you know what part is broken.
Does the car start if you jump the starter to the battery?
Old Mar 22, 2013 | 11:13 AM
fcm's Avatar
fcm
Old Fart
Any "sparking" at/from a ground lead indicates a poor ground connection.
A starter motor that just "clicks" can also be an indication of a poor ground, or poor connections in the solenoid...
https://honda-tech.com/forums/showth...cm+fix+starter
As mentioned, redo the main grounds, DO NOT just eyeball them or just tighten them, [disconnect, clean and reconnect], if that does not solve the starting problem test the circuit...
https://honda-tech.com/forums/showth...cm+bypass+jump
Good luck, feel free to IM me if you have questions. 94
Old Mar 22, 2013 | 01:28 PM
hookahpro's Avatar
No the car dont start when jumping the starter. But i randomly went down to my garage today and decided to try to start it again, and it started right up. Auto store said they think the solenoid is bad, and to just replace the starter. Also randomly driving it to the parts store, my RPM's shot all the way up on there own.... Bad TPS? i shut the car off and tapped on it with the handle of a screwdriver and it seems to be working fine now. just another thing to add to the list of this car.
Thanks FCM, ill pull the grounds off and clean them. see if that helps with it
LoicJoncourt
Aug 8, 2013 03:30 AM
B18CivicEH2
May 6, 2009 05:29 PM
Timmyflys
28
Jun 25, 2007 03:11 PM
.Grimace
28
Jan 12, 2007 11:30 AM
lazykiwi
Nov 27, 2004 04:17 PM
