2001 Civic Wont run?????
I am new here.
I have a 2001 civic 1.7L
I just replaced the timing belt and it was running fine for two months.
The car has 117,000 miles on it.
The other day I parked it and now it will crank and start and go to 3,000RPM and then to 0 and die.
The fuel pump is coming on. The engine is not making any funky noises.
I plugged it in and there is no codes on the computer.
I took the top timing belt cover off and everything I can see looks good. I dont think it jumped a tooth or anything.
Maybe the fuel pump is crapping out? Not enough continued pressure?
I dont know where to start now. It throws me off because it will crank, start and run but not stay running.
Any help would be appreciated.
Thanks
Thanks
The fuel pump does not have a required service date, and is submerged in the fuel tank.
Have you checked your crank position sensor, or any throttle body relative sensors?
ktmrider
Honda Civic (2001 - 2005)
Dec 15, 2013 02:14 PM
umair
Aug 2, 2011 11:06 AM
Dangousity
Feb 10, 2010 03:58 AM
AdamJ2
Jul 5, 2008 12:16 PM
