crx fan and thermostat problem
Old Mar 21, 2013 | 02:56 PM
jdm_ef66's Avatar
Default crx fan and thermostat problem
I need alittle help, i have a single zc motor in my crx and the fan isn't turning on... after alittle check, found out that i'm missing my thermostat sensor plug from my harness.... i don't know if its cut off or the harness is like that...
Old Mar 21, 2013 | 03:03 PM
4drEF's Avatar
Keyboard Humorist
Default Re: crx fan and thermostat problem
One end of the connector runs to ground - so that should be easy.
The other runs to the fan relay. IT is a yellow wire w/ green stripe.
EDIT: By the way, the stock ground wire runs up to the thermostat housing (G101).
Old Mar 21, 2013 | 04:13 PM
jdm_ef66's Avatar
yes i have that but missing the plug for the thermostat sensor
Old Mar 21, 2013 | 04:21 PM
4drEF's Avatar
Keyboard Humorist
You have what exactly?
You can add the plug... you are going to need it and apparently you don't have one.
You can open up your harness to see if you have the wires.
If you don't have the wires, or if you don't want to open up your harness, then you can add the wires to the appropriate places.
Old Mar 21, 2013 | 04:29 PM
jdm_ef66's Avatar
thanks alot, ill try that......
Old Mar 21, 2013 | 04:48 PM
jdm_ef66's Avatar
just open up the harness and i don't have the wires, any idea on how i can add it?
Old Mar 21, 2013 | 08:32 PM
4drEF's Avatar
Keyboard Humorist
Go look at the radiator fan relay for that yellow/green wire.
It's VERY suspicious that you don't have the wires for this.
All cars came with them from factory.
Old Mar 23, 2013 | 07:23 AM
RuneRavenX's Avatar
I have a similar problem. Except mine is intermittent and never comes on when it is supposed to. just randomly. All I have checked it ground wire because I put in a new thermostat.
Posted from Honda-tech.com App for Android
Old Mar 23, 2013 | 07:24 AM
RuneRavenX's Avatar
And I do not have missing wires.
Old Mar 23, 2013 | 05:54 PM
4drEF's Avatar
Keyboard Humorist
Do you have the radiator fan relay?
Old Mar 24, 2013 | 08:10 AM
RuneRavenX's Avatar
I have no clue. I've never had to mess with something like this before, I wouldn't know where to look. The fan comes on, but only at very random intervals. The temp will go up and the fan won't come on, but sometimes at normal temp it will. I have turned the car off and left the key on before, and the fan came on. Then I turned it off and back to on, fan came right back on like there was no issue. But it absolutely will not come on when it is supposed to.
Skeletor
Mar 13, 2008 12:23 PM
chirp the 1-2
Dec 12, 2007 06:47 AM
PAsol_er
Jun 21, 2005 09:39 AM
Layziebtnh055
11
Mar 23, 2005 06:44 PM
crishpen
Dec 2, 2004 10:51 AM
