crank case...tech question - help!
Old Oct 22, 2002 | 07:44 AM
Leo95SE's Avatar
Default crank case...tech question - help!
this no search thing is killin me..
can someone explain the purpose of the pcv/crankcase breather system to me?
i know (i think) how its supposed to be, i just want summin in writing to verify my thoughts.
isnt the air supposed to flow from intake to head, to pcv, to catch can, to eliminate spent gases/oil?
thx..
Old Oct 22, 2002 | 11:40 AM
Crazydave's Avatar
Default Re: crank case...tech question - help! (Leo95SE)
It removes gases in the crankcase and puts them in the intake to be burned..
helps with engine performance and emissions..
otherwise you would build pressure in the block..
Old Oct 22, 2002 | 12:43 PM
Leo95SE's Avatar
Default Re: crank case...tech question - help! (Crazydave)
ya i knew that part, but im confused on the direction/order of flow..
anyone got that endyn breather mod diagram/install instructions?
it shows flow direction, tube cut, etc..
thx!
Old Oct 22, 2002 | 01:43 PM
NonovUrbizniz's Avatar
Loved
the breather on top of your crankcase sucks in fresh air from the intake tube.
the pcv valve vents the oil-saturated fumes out of the engine crankcase and vents the air into your intake ( follow the tube coming off the pcv valve )
Old Oct 22, 2002 | 01:45 PM
Loved
Default Re: crank case...tech question - help! (NonovUrbizniz)
oh and as far as helps performance... not reallly the oil-soaked air that gets dumped into your intake causes detonation. so you ideally would like to have a filtering system in between the pcv and intake manifold
Old Oct 22, 2002 | 03:29 PM
Leo95SE's Avatar
so, the pcv and breather are two separate systems.
the breather is supposed to allow fresh air into the head, (why?)
and the pcv recircs fumes from block to the intake manifold.
and, i assume the reason that ppl see oily TB's is b/c the breather hose isnt doing its job, and is sucking dirty air into the intake tubing. correct?
ghostlude99
Oct 12, 2008 10:09 AM
lived dreams
Jul 19, 2008 08:46 PM
jvsucks
Sep 11, 2007 06:49 PM
DelSol941
Oct 11, 2003 08:34 PM
h22congee!
Oct 5, 2002 11:30 AM
